Wood Glue Paste/Putty
Introduction: Wood Glue Paste/Putty
About: Occupation: Tech Support
Sometimes wood glue is too thin for parts of certain projects. However, one can use wood glue to create a thicker paste to assist with filling in gaps and other aspects of woodworking, similar to wood filler:
Parts:
- Sawdust and/or thin napkin
- Wood glue (I used Titebond)
- Fingers
Teacher Notes
Step 1: Mix Wood Glue
1. Put a little wood glue on the end of your finger.
2. Dip the wood glue into the sawdust and start to mix with your fingers.
3. Tear a piece of the napkin off and mix with the sawdust/wood glue.
4. Once it is well mixed into a small glob, push into a gap between pieces of wood.
Fix It! Contest
Fix It! Contest
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Fix It Contest
      Fix It Contest
    3 Discussions
    RedshirtGamer
    RedshirtGamer
    4 months ago
    This works well, also for filling screw holes, larger cuts, etc. Short, sweet solution!
    gralan
    gralan
    1 year ago
    I dig the use of filler with glue. If you have a pencil sharpener with a trap to catch the shavings you could utilize that as well I would think. But I can get saw dust easy enough. Thanks for the tip.
    gralan
    gralan
    Tip 1 year ago
    Due to a lack of scale, I have no idea how big of a spot you were filling. I'll try this anyway. I get the idea.
    Thanks.
