Wood & Leather Backpack V1.0
853
12
6
Watching some cartoons with my kids I noticed a small backpack that I liked. After looking for photos on the Internet I decided to make one. This one is Version 1.0 because it's intended to be a learning platform so I can then make V2.0 (mine). I hope you like it and vote for it. I'm learning to work with leather but I have basic woodworking knowledge. That's why I decided to create a wood and leather backpack.
Step 1: Some Ideas and Initial Design
I had to choose a final design.
I like the form of the black and red backpack shown above, but I wanted the sides and bottom to be made of wood.
I did not like the brass tacks but later on I learned why they used them. For now, I intended to sew the leather to the wood.
Since I had enough leather for a small backpack, I decided it to be 10 inches wide, 3 inches deep, and 8 inches tall. Version 2.0 will be bigger and better!
The shoulder straps will come out of the sides and end on the bottom. I will use some magnets for closing the front.
Step 2: Materials
Recycled wood
2 leather pieces 12 inches x 24 inches
Needles and faux leather string
Double sided craft tape
Blue tape
Drill
Hole puncher
1/4 tap
1/4 inch-20 x 3/4 inch flat head phillips screws
Ruler
Nylon straps
Step 3: Cut, Drill the Wood and Prepare the Leather
I traced the forms into the wood from the paper patterns.
I recorded a video of these steps, but the file got corrupted and I could not fix it. @#$@$!~#
Next it's to cut the wood and then sand it.
Drill 112 holes 1/2" apart. It took me a loooong time!
The leather was cut following the design, and after using blue tape along the edges I used a ruler and a pen to mark the holes. Using the hole puncher, I spent a few hours punching holes to the leather.
Step 4: "Sew" the Leather to the Wood
Using a string, I attached the needle to the faux leather string.
It took me almost an hour to stitch the leather to the wood.
Unfortunately, I did not like the end result!
Lesson learned. It's easier to glue and nail the leather to the wood.
I undid the stitching and using double sided craft tape fixed the leather to the wood and stitched it all again.
Step 5: Shoulder Straps
From an old backpack I got the length of the straps. I cut (4) 18 inches long strips of the nylon.
I manually sew two strips to the brass adjustable slider, and added one grommet to each of the two remaining strips. It would've been very handy to have a Juki Serger at this point ;).
I measured and marked 2 inches from the sides of the bottom, drilled and tapped threads to the wood. After testing the straps I found out that they where too long, so I trimmed the excess. Then using the screw, I attached the straps to the bottom of the backpack.
Step 6: The Finished Backpack
Finally, after cleaning, I took some pictures of the backpack for the contest and gave it to my kid, so he could enjoy it (or destroy it *nooooooo*).
I hope this can help someone create a backpack like this one. It was more difficult than expected, but a lot of fun!
Backpack Challenge
Second Prize in the
Backpack Challenge
    • Sew Tough Challenge
      Sew Tough Challenge
    • DIY Summer Camp Contest
    • Games Contest
      Games Contest
    6 Discussions
    The end results is really quite awesome though! And I reckon it would be an awesome storage solution for breakable stuff if you needed something light and portable and easy on the shoulders. I would definitely consider making more of these too man - they're really quite nice, if I do say so myself!
    xpunkprDavid_Hamilton
    Reply 7 months ago
    It's definitely a versatile piece. If you do make one of these or something similar, do share!
    blkhawk
    Tip 11 months ago on Step 6
    Instead of drilling all those holes, you could use glue and thumbtacks to secure the leather to the pieces of wood.
    xpunkprblkhawk
    Reply 11 months ago
    Hi blkhawk,
    Thanks for looking at my Instrutable. I tried the brass tacks, but I didn't like how it ended up looking for this backpack. I will definitely try it on my next backpack project.
    Thanks for the suggestion.
    jessyratfink
    11 months ago
    That's really nice looking! Love how rigid the wood makes it. :)
    xpunkprjessyratfink
    Reply 11 months ago
    THANKS!
    It helps it keep its form and its actually comfortable to use.
