Wood Slice Ornaments
Introduction: Wood Slice Ornaments
How To Make Wood Slice Ornaments
Supplies:
  • Wood Slices
  • Paint Brushes
  • Acetone Nail Polish Remover
  • Mod Podge
  • Printer/Printer Pa
  • Ribbons
  • Drill
  • Lig
Teacher Notes
Step 1: Print Design
  • Find a design or designs that you like
  • print design(s)(reversed)
  • cut them out
Step 2: Transfer the Design
  • Place the design face down on wood slice
  • Brush acetone onto the paper
  • "Burn" the image onto the wood by rubbing over the paper with the end of the brush
Step 3: Seal With Mod Podge
  • Brush a thin layer of Mod Podge over the surface of the wood slices
  • Allow it to fully dry
  • Repeat on the other side of the wood slice
Step 4: Drill Hole & Add Ribbon
  • Use a drill with a small drill bit to make a small hole at the top of the wood slice
  • Put one end of the ribbon though the hole
  • Tie the ends together in a knot
  • Use a lighter to heat seal the ends(to prevent fraying)
Home Decor Contest
Home Decor Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
    seamster
    seamster
    5 weeks ago
    Great decor idea, thank you for sharing! : )
