Wooden Bracelet With a Four Leaf Clover Frozen in Epoxy - No Lathe Needed!
3,716
64
4
Introduction: Wooden Bracelet With a Four Leaf Clover Frozen in Epoxy - No Lathe Needed!
About: Page created from a passion to design and woodworking. You can find here home decor ideas, bespoke furniture, handmade cutting / chopping boards, serving boards, cheese boards, coasters and many more.
Welcome to my post!
I will show you how you can make a wooden bracelet with an epoxy inlay with a four leaf clover.
Step 1: 1.
First step – we need four pieces of wood, preferably in different colors for a better effect. I’m using walnut and ash; this gives a very nice color scheme. The smallest piece of wood was 13.5cm x 8.5cm x 2cm
Step 2: 2.
Next step is glue all four pieces together. Make sure the faces that will be glued together are flat. I suggest running them through a jointer, this will ensure the best glue up.
Step 3: 3.
When the glue dries we need to clean up the wooden block and make sure that two sides are flat. This is important for the next step.
We need to mark the center of the block and on a pillar drill using a large forstner bit (mine was 7.5cm) we need to drill a hole. The size of the forstner bit depends on the size of your customer’s hand.
Step 4: 4.
Now we mark the size of the outer border of the bracelet – I just used a roll of tape to mark my outer circle. Then we move to a bandsaw to cut out the shape.
Step 5: 5.
After that we just need to clean up the band. I’m using a random orbital spindle and belt sander to achieve the final shape.
Step 6: 6.
Next we are back at the bandsaw and cutting the band in half – now we got two. You can use less layers of wood or have them thinner. But in this way you can produce more bracelets in one go.
Step 7: 7.
In the next step, using a drill and a forstner bit we drill a hole in the bracelet. We need to clean it up and from the inside of the bracelet we will be using a transparent tape to cover the whole hole. Make sure you are extra careful in this step and do a good job in sealing the tape. This will prevent the epoxy from dripping out. On the top I’m using hot glue around the hole to create a border so epoxy will not escape or cover the rest of the bracelet.
Step 8:
Now it’s time for the epoxy. Mine comes in two parts that need to be mixed in equal amounts. For better results with no air bubbles I have put the part A (not the hardener) in warm water for few minutes. It will become runnier and it’s easier to mix it. Pour some of the mixed epoxy in, wait 5 few minutes and then place the four leaf clover in the middle and gently sunk it in the epoxy. After few minutes pour the top coat on. And now leave it to cure.
Step 9: 9.
After that we remove the tape and glue and proceed to sanding. First of all I’m back at my random orbital spindle and belt sander to get the shape back. Then we need to sand the project starting with grit 320 right up to 3000. In my case grit 1500 and 2000 was wet sanding.
Step 10: 10.
In the next step I have used some Danish oil to bring the best from the wood, total of two coats. Then I have used a buffing compound and a buffing wheel to bring the sheen to the bracelet. And the bracelet is now ready for you to enjoy.
You can also check my YouTube video with the whole build, link:
https://youtu.be/ObmqKUmdDIU
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Maps Challenge
      Maps Challenge
    4 Discussions
    Artuino
    Artuino
    1 year ago
    That is one lucky charm idea.nice work!
    Capt Caveman
    Capt Caveman
    1 year ago
    Very nice looking...although you might want to put in the title or description that 'yes' you dont use a wood lathe, but you do use pretty much every other power tool in a Wood-workers workshop! lol
    technofossil
    technofossil
    1 year ago on Step 10
    Thank you, great project. Well designed and explained.
    My only comment is that I would drill the hole (your step 7) before you bore the first hole in step 3, there will be no need to clean up that hole at all. This will allow you to clamp the piece while it still has a large flat surface. It will be easier to clamp to the drill press and have less chance of it kicking out when the drill first hits the round side. Additionally, when you clamp the round bracelet to a flat surface, there is always the risk of it cracking.
