Wooden Chopping Board
Introduction: Wooden Chopping Board
Wooden chopping board.
Supplies:
  • Spruce Wood - 7cm wide and 90cm long.
  • Jigsaw
  • Linseed Oil
  • Wood Glue
  • Wood Cutting Table
  • Sandpaper
  • Paint Brush
  • (optional) Drill
Teacher Notes
Step 1: End Product
This is what the end product should look like.
Step 2: Gather Supplies
Collect everything needed to make the chopping board.
You will need:
Spruce Wood
Jigsaw
Mineral Oil
Wood Glue
Wood Cutting Table
Sandpaper
Paintbrush
(optional) Drill
Step 3: Cut the Wood
First, you need to cut the pieces of spruce wood with the jigsaw. You will need 3 pieces, each 4cm wide and 30cm long.
Step 4: Gluing the Wood Together
Next, glue the pieces together using the wood glue.
Step 5: Optional: Drilling a Hole
(This is optional) If you like you can drill a hole wherever you want on the board.
Step 6: Sanding the Board
After that, use sandpaper on the whole thing, until it's smooth.
Step 7: Oil
Finally, you will need to brush linseed oil all over the board, using the paintbrush and wait for it to dry.
Step 8: Finished Product
You are done! Your chopping board should look something like this.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
