Wooden Decoration: Candle Blocks
Introduction: Wooden Decoration: Candle Blocks
Usable all year long. Simple design for all.
Teacher Notes
Step 1: Design and Prototype
First of all, I designed the sizes and shapes on a piece of paper to find the correct size and shape. I chose a 5x5 cm block.
In the next step, I designed a prototype to test out if the sizes would fit and to make sure the final products would turn out correctly.
Step 2: Holes and Sanding and Dowels
Next, I drilled candle holes in the top block of each of the four-block compositions. and then went on to sanding the block which was supposed to be glued together so that they would fit each other. To make sure that the blocks would not move while sanding I used dowels to fix them together.
Step 3: Gluing
The dowels later would also be used in the gluing process because it would make the glue stronger and the blocks hold together better.
Step 4: Varnish
My last step was to varnish the blocks with a grey Lasur which I chose and added the candle holders.
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    Penolopy Bulnick
    Penolopy Bulnick
    10 days ago
    You have a lot of fun candle holder designs :)
