Wooden Loo Roll Holder
445
6
Introduction: Wooden Loo Roll Holder
About: I am a Marine Engineer in the RNZN (41 years done in various navies) and am looking forward to retirement!!! so I can do more messing about with tools
We have had these chromed plasticky loo roll holders since we moved in, and they are always coming loose and flopping about, they also look and feel cheap, I quite like the overall design so I'm sure I can make something nicer
Step 1: The Wood
I had some scrap mahogany and kwila decking boards that I "rescued" from a skip, so I cut them down on the table saw.
These woods are pretty hard and the saw definitely didn't enjoy it much! :-)
Step 2: The Spindle
I mounted the spindle in the lathe and turned it down to approx 15mm and sanded it with 60,80,120,240,300,and 400 grit paper
It was the cut to length to get rid of the end holes
Step 3: The Wall Mount
Originally I was intending to try and mount this the same way as the original so I drilled out a recess with a 32mm spade bit, however I realised that this would be impractical, it didn't matter as the piece could still be used.
I then mounted it in the lathe and turned the shape I wanted and again sanded
Step 4: Shaping
I shaped the end of the wall mount to fit around the spindle using a sanding drum on a Dremel
Step 5: Joining the Pieces
I drilled a 3/8 hole in both pieces so that I could join them using a dowel (originally I was going to use a dowel screw (a double ended screw) but it seems that they are unavailable in NZ!)
I also drilled al lthe way through the wall mount with a 4mm drill for the mounting screw
Step 6: Stopping the Loo Roll Falling Off
I needed a "stop" for the Loo Roll so using a hole saw I partially drilled through a decking board, I then removed the centre drill and cut the rest of the way through
Step 7: Finishing the End Stop
I drilled a 15mm hole in the end cap about halfway through using a Fostner bit
Step 8: All the Bits
The end stop was glued on using waterproof wood glue and the dowel glued into the spindle ready for mounting
Step 9: Fixing the Mount to the Wall
I used a 75 mm screw to mount to the wall, I varnished the part nearest the wall with marine varnish before screwing up tight (so I didn't get varnish on the wall being hamfisted!)
Step 10: I Then Glued the Spindle to the Wall Mount Using the Dowel
A gentle tap was needed to push the dowel all the way home, I then varnished the rest of it
And job done - 3 more to do!
Be the First to Share
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
    • Tinkercad Student Design Contest
