Introduction: Wooden Moose Skull
Some tools you may need.
1: Grinder with a special woodcarving wheel
2: Chainsaw
3: Drill with large forstner bit
4: Hand Chisels
5: Sand Paper
6: Finish
Step 1: Step 1 : Watch Video
Step 2: STEP 2 : Layout
Layout your top view and side view.
I printed out a large top and side view of the skull and cut out the outline and traced it onto the wood with a sharpie.
Step 3: STEP 3 : Trim Away Extra Wood
Using a chain saw cut away any large chunks that are outside of the top and side profiles.
Step 4: STEP 4 : Carve
Using your grinder carve up to the lines you traced onto the block of wood.
Step 5: STEP 5: Use a Reference.
I found a complete 3d model of a moose skull on my phone that I could rotate to use as a reference since i didn't have an actual moose skull to look at. Looking at the model I added more reference lines to block and carved away any unnecessary wood.
Step 6: STEP 6 : Eye Holes
Using a forstner bit the size of your eye socket carve out the eye. Be sure to drill slightly toward the back and not straight in.
Step 7: STEP 7: Clean Up With Hand Tools and Sand
Using hand tools clean up the final bits of wood. Sand as smooth as you like. I liked the look of some texture so i didn't sand too much.
Step 8: STEP 8: Add Antlers
Drill a hole in both your block of wood and your moose antler to insert a 1/4 inch steel rod. Secure the steel rod into the wood and antler using a healthy dose of 5 minute epoxy.
Step 9: STEP 9 : Add a Finsh and Enjoy
Add a finish of your choice to your newly carved wood skull let dry step back and enjoy.
Sculpting Challenge
