Wooden Pot
About: Graphic designer - diy enthusiast
I've used wooden lath for this project. Cut into pieces and then had some glue on each piece & joined them.
For the ones who want to try this, I can say that you should use something for the water sealing inside the pot. Because by the time, water spoils wooden pieces.
Teacher Notes
Step 1: Building the Frame
I've used wooden laths and cut them. Then applied some glue on each piece & put on top of each other.
Step 2: Painting
I've painted it white. But for an outdoor pot, you should renew the painting at least once a year.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
