Wooden Show Stand
This is a Wooden Show Stand to put some small belongings on and maybe even a trophy.
Supplies:
Things you will need:
- wood that is at least 1 foot x 1 foot x .110 in - Laser Cutter - Any type of designing software - Hot glue (Or any glue for wood) - paint if you decide to paint yours
Teacher Notes
Step 1: Design the Sides
First thing you want to do is make multiple sides with indents of the material thickness(.110) in the center and the sides should be 5in x 2in (X2) and 3in x 2in (X2)
Next pick out your designs and set them up on each side how you want them.
Step 2: Cutting
Next Export your file as a DXF and cut the peices out
Step 3: Analyze Your Pieces
Look at them and see if they turned out how you wanted them, repeat steps 1 if they are not what your looking for.
Step 4: Glue
Glue your peices together sides first then place the top piece on the top and secure it with glue.
Step 5: Finished
Tada! You have made your wooden show stand and its ready to be painted or put to use right away.
First Time Author Contest
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    seamster
    21 days ago
    Looks good!
