Ray Ban AviatorRay Ban Naočale
21
Introduction: Ray Ban AviatorRay Ban Naočale
began tinkering with wooden sunglasses after several frustrations with fixing cheap plastic pairs. This guide will help you transform nearly any pair of sunglasses into wooden eye-wear with a little over an hour of work.
Teacher Notes
Step 1:
Eventually I will provide some detailed steps on cutting the frames from wood as well as creating the original stencil. However, this step shows the frames being soaked in water prior to bending.It just so happens that many pots used in the kitchen are the perfect size for bending sunglasses because the pots are slightly larger than a human head. The clamps must be kept in place for a day before removing.
Step 2:
The finished glasses with the arms attached and the lenses sandwiched between the pieces of the frame. Sunglasses looks almost like the real aviator ray ban naočale.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
