Introduction: Wooden Wine Holder
Hello!! this is a simply to build wine holder, using just pine table and a few paint.
You can build it in a few time. The more is to wait for the paint to dry.
The build is very simply, but the main goal is to produce a brushed finish, to give it an antique and raw effect.
I'll make no steps as it is very simple build.
Just use a steel brush to make veins came out from the wood.
A 42x30 cm table is enough to keep a couple of bottles. I made two to give some simmetry to the room, as I have a paint in the middle.
Once you have evident veins use a bit of sandpaper to make everyting softener. Then, just use a bit of paint. I lilke this effect made from antique nutshell paint. The brackets are very simply, with 45 degree cuts, and a center hole just enough to put a wine bottle into.
I user a couple of screws and vinyl glue to fix the supports to the table.
I'm quite satisfied with the results.
