Wool Beanie
Introduction: Wool Beanie
Want a way to stay warm in the cold try making this beanie it is so easy and quick so try making this.
Supplies:
yarn needle
#6 yarn/ thick yarn
hook
medium round loom
Teacher Notes
Step 1: Hooking Over the Yarn
Use the hook and reach under the loop on the bottom and pull it over the peg.
Now repeat steps 1 and 2
Step 2: Casting Off
Make sure there is one loop on each peg.
Cut the yarn from the last peg and tie a knot at the end.
Then thread the yarn through the eye of the needle and like the hook pull it over the peg.
Step 3: Turning It Into a Beanie
Pull the yarn on top as tight as you can to form a closed top and tie it off.
There you have it you have a beanie now
Step 4: Starting the Loom
You want to tie a secure knot on the knob of the loom.
Then you want to form a backward p go around twice
Warm and Fuzzy Challenge
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
