Working With a LED and a Push Button Using Arduino in TinkerCAD
This project demonstrates working with a LED and a Push Button using Arduino in TinkerCAD circuits.
Teacher Notes
Step 1: Objective
  • Make the LED ON when the Push Button is Pressed.
  • Make the LED OFF when the Push Button is Pressed.
Step 2: Components Required
  • Arduino UNO (1 No.)
  • Breadboard (1 No.)
  • Resistor 1k ohm (2 No.)
  • LED (1 No.)
  • Push Button (1 No.)
  • Jumper wire (5 No.)
Step 3: Breadboard Diagram
Make the connections as shown in the figure above.
Step 4: Block Code: LED Turns ON When Push Button Is Pressed
Step 5: Block Code: LED Turns OFF When Push Button Is Pressed
Step 6: Start Simulation
Click Start Simulation to see the action
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
