WorkshopBy DavidFerAndersson in WorkshopTools17,46789 Suggested Projects FavoriteA collection of tools, tips and guides for use in the workshop.A collection of tools, tips and guides for use in the workshop.Hanging Camera Slider With Arm Extensionby tlee2 in WoodworkingHanging Camera Slider With Arm Extensionby tlee2 in WoodworkingBandsaw Circle Cutting Jigby TheWoodKnight in Woodworking Ultrasonic Misting 3D Print Vapor Polisherby MechEngineerMike in 3D Printing Ultrasonic Misting 3D Print Vapor Polisherby MechEngineerMike in 3D PrintingDIY Lathe Add Ons by adenda2 in ToolsClassic Heat Exchangerby bertus52x11 in ScienceConvert a Hand-held Circular Saw Into a Table Sawby neffk in ToolsCheap and Easy Desktop Electric Outletby D Jason Payne in WorkbenchesHow to Make a Heat Sealerby klee27x in ToolsHot-Wire Foamcutter (Battery Powered)by clement.fletcher in ToolsMake a Good, Cheap, Upgradeable Sheet Plastic Vacuum Formerby drcrash in ToolsMake a Manual Vacuum Pump for Under $20 by Converting a Bicycle Pumpby drcrash in BikesThe Simplest Bicycle Framebuilding Jig I Could Come Up With...by drwelby in BikesHot Wire Foam Cutterby flywoodkb in ToolsHotwire Foamcutting Tableby TimAnderson in ToolsScreen Printing: Cheap, Dirty, and at Homeby tracy_the_astonishing in Fiber ArtsEasy Fork Blade Bendersby drwelby in BikesBuild a 4 Color T-Shirt Printing Pressby Progfellow in ToolsDown and Dirty Screenprinting for Under 10$by woodenshoespress in PrintmakingMini Cyclone Bucket Dust Collectorby Steliart - Stelios LA Stavrinides in WoodworkingAlmost Free Solar Hot Air Collectorby ecosteve in EnergyLED Bead Jigby Carleyy in LEDsDIY Wood Burner Pot Belly Stove. Made From a Gas Tankby Dr Qui in BBQ & GrillingMini-Tablesaw / Router / Shaper for Dremel Rotary Toolby sdudley in WoodworkingMy KISS Lathe (mi Torno HSE)by rimar2000 in WoodworkingOhm's Lawby josh1324 in ElectronicsHow to Make Your Own Sugru Substituteby mikey77 in ScienceElectronic Parts Cannibalizingby jcoronel in ReusePocket Laser Engraver.by Groover in ToolsHomemade Rotary/Flat Engraverby hack818 in WoodworkingDIY CNC & Constructing an Affordable CNC Kitby CNCSnap in CNCPt. 1 How to Build a Potters Wheel With a Treadmill Motor!by rasro24 in ClayManaging Limited Desktop Space and Multiple Projectsby Neurogami in ToolsGlass Bottle Cutterby warehouse32 in ReuseHacking Drills- Cheap/Powerful Gearmotors for Robotic Applicationsby AlexHrn in RobotsEvolution of a Ring Bender / Ring Roller Machineby jds1969 in ToolsBuild a Down Draft Tableby WorkshopAddict in WoodworkingAnother DIY Vacuum Formerby cmonaco3 in ToolsHow to Make a Wind Tunnelby jamesabt007 in CardboardFeatherboard Evolutionby flavrt in WoodworkingWoodstove Heat Exchangerby VertDude in EnergyCNCby Instructables Guides in CNCHydraulic Ram Pumpby habolooby in Energy~ World's Greenest WATER PUMP ~by eltigre in ScienceCheap and Easy Passive Solar Water Heater for Your Home. ($300)by jaketeater in SolarMini Circular Saw Tableby ric12335 in WoodworkingCollapsible Spray Boothby Jeffster in ReuseDIY Glove Boxby DIY Hacks and How Tos in ToolsSacrificial Square for Pillar Drill / Drill Press Table - Part 2by savvas_papasavva in ToolsMake a Router Lift Out of Recycled Closet Door Rails.by urant in WoodworkingHow to Build a Workbenchby Sam DeRose in OrganizingMini Chamfer Plane Mod (from Harbor Freight Mini-plane)by rhoddity in ToolsVacuum Forming Rigby stechi in ToolsDIY Portable Fume Extractorby agomes6 in ElectronicsHomemade Portable Bandsaw Stand - Cut Off & Verticalby savvas_papasavva in ToolsHow to Steam Bend Woodby savvas_papasavva in WoodworkingFitting Bits Into Tool Chest (router, Flat and Forstner Bit Holders)by savvas_papasavva in ToolsMagnetic Ball Bearing Internal Curved Surface Dent Removerby Fikjast Scott in ToolsMini Router Tableby ric12335 in WoodworkingMini Edge Sander - Belt Sander Standby savvas_papasavva in ToolsTap Jig (very Quick and Very Dirty)by snotty in MetalworkingImprove an Inexpensive Scroll Saw - Add Knobs!by vreinkymov in WoodworkingCardboard Blade for Tablesawby BoilingLeadBath in CardboardMinimalist Bench Sanderby klee27x in WorkbenchesWood Shop Must Have Domino Joinerby longwinters in WoodworkingGarden Room - Workshopby theoblackadder in Home ImprovementBuild a Sander/Vacuum Box Dust Collector (for Your Girlfriend)by damianzuch in WoodworkingHow to Bend Pipe Without a Pipe Benderby ayasbek in MetalworkingRound Bench Dogs With Non Damaging Nylon Springsby acesoft in WoodworkingThe MicroSlice V1 | a Tiny Arduino Laser Cutterby Greg_The_Maker in Laser CuttingSuper Workbenchby urbanmx in WorkbenchesDrywall Sanding Dust Collector/Separatorby Randyrandy74 in Home ImprovementTurn a Fail Into a Featureby bongodrummer in WoodworkingHow to Make a Better Cross Cut Sledby joelav in WoodworkingBathroom Cabinet With Curved Doorsby admarschoonen in WoodworkingThe Bare Woodworking Essentialsby MyHobbyStore in WoodworkingBuild This Woodworker's Workbench to Learn Mortise & Tenon Joineryby KentM in WorkbenchesSphere Center Align and Drill-O-Natorby -BALES- in ToolsSplined / Keyed Mitre Sledge / Sled and Box - Building and Using on Table Sawby savvas_papasavva in WoodworkingPyramid Jig - Equilateral Triangleby savvas_papasavva in WoodworkingWire Benderby Jacob.Runyan in MetalworkingBent Lamination Form (How To)by wizzinstuff in FurnitureSimple Tilting Router Table Insert / Table Saw Extensionby savvas_papasavva in WoodworkingExtreme Heavy Duty Work Benchby Bengt Englund in WorkbenchesLeather Tooling Punchesby cbm104 in LeatherAnvil Standby bennelson in WorkbenchesSuper Silent Compressor Built Out of an Old Fridge/Water Coolerby antagonizer in ToolsANICE Stoolby Tart2000 in WaterHomeMade Modern DIY $5 Bucket Stoolby homemademodern in FurnitureParacord and Pulley Hanging Tableby Matt Makes in WoodworkingParacord Bracelet Jigby Wink79 in WoodworkingChainsaw Mill Build, Use & Tips N Tricksby bongodrummer in WoodworkingInexpensive Dremel Router Attachmentby vreinkymov in ToolsWooden, Cyclone Seperator Shop Vacby broken board in WoodworkingWORKBENCH WOODWORKINGby broken board in WorkbenchesElectronic-Lab in a Boxby McLovinGyver in ToolsWooden Architect Lampby action pig in LightingA Simple Machine for Drilling Stand-offsby HomeCSP in ToolsCyclone Separator for Shop Vacuumby broeand in ToolsEtching on Any Surface Cheaply and Without the Use of Chemicalsby antagonizer in ArtMaking a $70 Glass Etching Tool for Less Than $10 Comparable to the Air Eraserby antagonizer in ToolsBending Thin Wall Tubing for Bicycles and Furniture - Poor Man's Mandrel Bender by Tiedeken in MetalworkingPrecision Hot Glue Gunby Dan Lockton in ToolsRoad Caseby techshop_android in TravelElectroetching Metal(s)by Switch and Lever in MetalworkingMake a Portable Workstationby Benne in WorkbenchesBow-Front Drawer Faceby Rockitalk in WoodworkingSimple Styrofoam Hot Wire Cutterby bulau65 in ToolsHow to Build a Fiberglass Sub Boxby bgugino in SpeakersDIY Sand Blaster $50 in an Hourby ImakeTV in ToolsBuild Your Own 3d Printer Filament Factory (Filament Extruder)by ianmcmill in 3D PrintingHow to Repair Your Worn Out Solder Tipby ianmcmill in SolderingHave an instructable you think should be included in this collection?SubmitSuccess!
