XBox360 Arcade
4,757
33
3D printing and designing RaspberryPI projects for a few years now
XBox360 Arcade - using a computer monitor speaker parts and 2 fightstick game pads, make an exciting arcade for your own home.
Teacher Notes
Step 1: Supplies Needed
Black Gloss Paint
Clear Gloss Coat
1 inch Hole Saw
Particle Board
1x4 Wood Planks
Green TMolding
Step 2: Supplies Needed (cont...)
24 inch Monitor
Mini 12v Amplifier
XBox 360
HDMI Extractor
Power Strip
RCA Cables
Small Speakers
Illuminated Buttons
Step 3: Supplies Needed (cont...)
Illuminated Buttons Kit
Exterior Decals
Embossed Branding Stickers
Step 4: Supplies Needed (cont...)
XBox 360 Controllers (x2)
Fightstick (x2)
Step 5: Building the Arcade
Because the Fightstick joysticks need an actual XBox360 controller plugged in to work and the "home" button has to be physically pressed on the joystick before the fightstick connects correctly, the following is needed to get the "home" or "player 1 / player 2" buttons to work on the arcade.
Take 2 XBox360 controllers and disassemble them. Where the buttons would normally "press" (the circular metal contact connection), use a light sandpaper to expose the metal. Soldered a "home" button connection directly to the contacts of where the home button would normally press if it was still put together. This lets the joystick button "press" home as if it were a rubber button inside the original controller.
Step 6: Building the Frame
Build a basic Frame from the 1x4 planks to hold the monitor in place in the shape of an arcade cabinet.
Step 7: Fit the Monitor
Make sure the monitor fits correctly across the build.
Step 8: Cut the Monitor Support Slit
Using the table saw, don't cut all the way through, but leave a slit in the wood where the bottom edge of the monitor would go, this will allow to place a thin piece of balsa wood to fit along it to keep the monitor from sliding out forward.
Step 9: Drilling the Holes for the Buttons
Using the fightstick button holes as a guide, drill using the 1" hole cutter the holes for where the buttons will go.
Step 10: Cut the Side Panels
With the particle board, cut the side panels with a triangluar slant, however leaving the top in a square shape to contain the "top bar" where the amp / speakers will go.
Step 11: Place the Monitor in the Build
Place the Monitor in the Build to Make Sure Everything Lines Up.
Step 12: Rounded Edges
Cut Rounded Corners on the Edges of the Button Panel.
Cut the rounded corners in the button container using a jigsaw and the small paint can as a guide to make it rounded off.
Step 13: Get the Amp and Speakers Together
Take the woofers and tweeters out of the speakers, we'll use them for the arcade build by installing them directly in the arcade top panel.
Step 14: WIRING DIAGRAM
Follow the above wiring diagram to ensure you have all the right pieces connected together.
Step 15: Button Illumination Power
Gather Button Illumination wires to power all the button lights via 5v USB source.
Prepare all the illuminated buttons for mounting in the cabinet. Make sure all the wires are color coded for ease of construction, illumination lights as black and red. Bound all the wires together so that the entire set of buttons receives power for illumination.
Step 16: Extract Fightstick Circuit Boards
Take the back off the fightstick and observe the connections, we'll have to duplicate this inside our cabinet ourselves when we wire it together.
Note the circuit boards inside specify conveniently which connectors go to the A/X/Y/B buttons and so on for our guide when wiring the cabinet.
Step 17: Install the Buttons in the Arcade Cabinet
Connecting the buttons to a USB 5v power source (with 2 amp or higher rating) make sure they all illuminate correctly and with enough current.
Step 18: Cut Speaker and Amp Cutouts
Using a small jigsaw cut holes for the 2 tweeters / woofers and small amp and make sure the mount correctly.
Step 19: Install Decals on Arcade
Gather all the decals together and cut the 2 largest decals to make them appear on each side of the cabinet.
Step 20: Mount Internal Components
Mount the internal components and power source for final assembly.
Tape over the home button controller buttons to make sure that the wires stay put.
Step 21: Rear Power and Connections
Cut hole in back to power the unit and connect the console.
Cut a hole in the back for the wall power to enter and for the 2 controller USB cables / HDMI cable to extrude from to connect to your XBox360 console.
Step 22: Apply Decals to Top Bar
Place the decals squarely on the top bar where the speakers and amp are mounted. Flip it over and cut with a razer blade the holes correctly.
Step 23: Wiring the Top Bar and Install It
Make sure the top bar has the wiring it needs.
1) Power for the small amp.
2) Sound output coming from the HDMI audio extractor.
3) 5v power for the buttons (black and red wires)
4) Button leads (green and yellow wires).
Step 24: Apply the Green TMolding
Attaching the Green TMolding along the edges for a proper arcade cabinet look - I've used simple glue to glue the TMold to the edges of the arcade (cutting off the T part on the bottom) If you do have a nice router you could cut the slots in the wood to have the TMolding fit correctly.
Step 25: Final Look!
Step 26: Mount the Amp With a 3D Printed Frame
Mount the amplifier in the top bar using the 3DPrint/ folder "AmpSurround-Final.stl" model file to create a nice looking Amplifier black frame.
The github project is here for the file:
https://github.com/khinds10/XBox360Arcade
Step 27: Finished!
Plugin your XBox and Cabinet and you're ready to go!
Game Life Contest
Game Life Contest
Be the First to Share
    • Home Decor Contest
      Home Decor Contest
    • Furniture Contest
      Furniture Contest
    • Reuse Contest
      Reuse Contest
    2 Discussions
    seamster
    1 year ago
    Very nice, this turned out looking so good. Awesome, my kids would love this : )
    JustinC318seamster
    Reply 1 year ago
    can some one tell me the parts i need to buy to make my ps2,wii and xbox 360 a timed arcade coin op machine and/or an instruction manual please,please help,any info would be great,ive been interested in it for years and searching internet for ages,i ask the company where i can get parts like a timer board but they NEVER helped me yet,otherwise i wouldnt be asking here,please help anybody,so i can begin the project soon
