Yellow Illusion (imitating Felice Varini)
285
Introduction: Yellow Illusion (imitating Felice Varini)
So, it turned out that we collected several things in one place:
Abandoned boiler room
Stepladder ladder
Old water dispersion paint
Yellow tinting paste
Chalk for marking
Ruler or small flat bar 1,5-2m
Paint brushes and paint cans
tripod
Scotch
Some cardboard
Half day free time
Rags to maintain cleanliness
In short, enough things to try to repeat the illusion of Felice Vapini
A simplified version, of course.
And at least two people.
Step 1: Attention!
If you work in an old building, first of all make sure that nothing falls on you. Take care of yourself.
Pay special attention to your safety.
Step 2: Draw Boundaries
It was decided to draw a triangle.
The maestro uses a projector for marking,
Alas, we are deprived of this opportunity.
Therefore, we make the device.
It consists of cardboard with a triangular hole and an emphasis.
All this is fixed on a tripod with adhesive tape.
The idea is that we can look from a fixed point through a triangular notch. By combining the borders of the stencil and the wall, you specify where to place the marking points.
Step 3:
You command your partner, “left-right”, “higher-lower” until the chalk in the partner’s hand is in line with the stencil border.
Step 4: Paint Over
After applying the markup can be painted.
Prepare the paint in a volume sufficient for all works, the color should not differ.
The process can be controlled by snapshots. This is more convenient than using our improvised device.
It is necessary to photograph from a point located in front of the stencil.
It must be something like this.
Step 5: The End
Colors of the Rainbow Contest
Be the First to Share
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    • Make it Move Contest 2020
    2 Discussions
    Alex in NZ
    Alex in NZ
    1 year ago
    Impressive. Thank you for sharing your work. I can just imagine how striking that would be if one stumbled across it by accident. :-)
    Slon
    Slon
    Reply 1 year ago
    Thanks for the kind words! People often walk in this place. This is a short way)
