Bowl Pick Bic Lighter
13,112
9
18
this is how to transform your ordinary bic lighter into lighter/ bowl turner/ stir tool/ pokeyjab/ bowl packer/ scraper/ whatever you wanna call it.
Step 1: Lighter
get yourself a bic lighter that still has the thumb safety.
Step 2: Disassembly
pry up thumb safety as shown
Step 3: Removal
remove thumb guard and metal housing entirely.
EDIT: easy tip for straightening , at this step before removing the housing, insert the toothed part into the slats on the back and bend backwards over the striking wheel.
Step 4: Augmentation
next grasp the flat part of the thumb guard with pliers. bend guard away from pronged teeth on flat part of guard.
Step 5: Housing
squeeze metal housing so it will stay on but leave a gap.
Step 6: Assembly
slip guard under housing, flat part up, pronged teeth down. then press housing into proper place (this will be very snug, even unlightable, guaranteed to jam if no more steps are followed)
EDIT*
to put the pick directly off the back of the lighter: before replacing housing, melt plastic in desired place and press the pronged end in the melted plastic to make a place for it to set and still avoid jamming. replace housing . pick is more comfortable to pocket this way.
Step 7: Heat
at this point you can straighten the new pick as you see fit.
add heat to melt plastic at base of pick.( ignore if you followed edit in step 6)
while plastic is hot use something to press downward on the housing, this will set the pick in its own spot.
Step 8: Safety First
pick is best off to the side because it jams the mechanism less. check for jamming by pressing button and releasing then listening for gas, and striking repeatedly. if it stays lit blow it out and jiggle the pick. you do want pick a little loose, as to prevent further jamming.
Step 9: Finito
there you now have your own pic bic!
      • Big and Small Contest
      • Holiday Decor
        Holiday Decor
      • PCB Contest
        PCB Contest
      18 Discussions
      brady75
      7 years ago on Introduction
      Why not just use a LighterPick? Seems easier and cleaner...
      jmtinfinitet
      9 years ago on Step 9
      lalettab for the record it doesn't matter if you use a sewing needle or a toothpick whatever cleans out your bowl. and to rockerton pretty cool idea except i can't imagine putting this lighter in my pocket. how does it work for you?
      rockertonjmtinfinitet
      Reply 9 years ago on Step 9
      works fine for me. straight off the back of the lighter is comfy in my pocket.
      pyro13
      10 years ago on Introduction
      You son, have just solved a big problem of mine. Now i have a bowl scraper, that i can't lose!
      waz444
      10 years ago on Step 9
      Just goes to show that stoner's do their best work stoned. "If I had a couple of hotties now i would be in a better place other than work"
      rockerton
      the glass peice in this inst was recently stolen from me, and it saddens me because i had it a substantial amount of time
      rockertonganjabomber
      this is for turning/ stirring/ flipping/ scraping the weed (or whatever you smoke) in your pipe.
      Please don't add unrelated keywords to projects, i had to sit deleting each unrelated one by one, also please remove this from the bike contest before staff have to bother. Not a bad idea, still I just use a clipper... I left the drug ones in even though it's not the best of ideas to advertise it, you get a bunch of people whining about how they're bad...
      rockerton
      i'm not a glass afficianado, i'm a stoner.
      lalettab
      All the glass aficianados I have known have told me that you don't put metal in there.
