Sypran's Knex Ballista
10,792
15
55
About: My life is 3 things Engineering,Music,and Movies Life would bore me otherwise I want to do more Fun things yet i cant because Evil teachers who give HW Like my poem? sadly its all true --- ------------...
Ok this is my first instructable, it is a cross bow with a new bow system (at this curent time) i hope u like it.
Ok for this pic you can see it has no trigger, that's because in not good at makeing trigers, well for crossbows anyway...
I don't know the range of it for i use weak rbs do to all my good 1s r ether :under something, destroyed by my cat, or put somewhere without me knowing... Ok anyway i used 2 hairbands on the limbs and they work really good, for me it fires 30ft before it hits something (this is with my ammo that i made, last step shows the ammo and how to make it)
Step 1: The Stock Pt 1
this is rather easy
7 blue rods
9 yellow conecters
1 grey connecter
(note that the blue behind the yellow is in middle connection thing not the hole except the 1 near my hand thats in the diagonal 1)
Step 2: Back Wheel
the back wheel is not important, (the wheel its self everything else I think is)
5 orange conectors
2 red rods
2 gray conectors
1 small wheel
1 blue rod
Step 3: The Crossbow Limbs
ok this is the crossbow limbs, of course you goto build 2
12 white/silver rods
4 white conectors
8 orange conectors
2 grey conectors
2 green/black rods
Step 4: The Top
OK this is going to be the top for the crossbow/ balista
14 grey connectors
1 yellow rod
4 yellow conectors
1 red rod
1 black idk what to call but its half connector half rod
2 green/ black rods
Step 5: Botten of the Bow Part
the bottom of this bow
1 yellow rod
5 yellow conectors
1 red rod
10 grey conectors
2 green/ black rods
2 half rod half connector things
Step 6: The Conection Point of Stock
this will be later used to connect the bow part to the ending stock
2 yellow rods
4 green/black rods
4 blue circle things
4 yellow connectors
Step 7: Peices Ull Need Later
ya these you will need a bit later.
Step 8: Step 1+2 Conected
simple connection between step 1 and 2 you'll do on both sides
Step 9: Step 6+ Step 8
OK there is 4 added pieces the wheel is on the other side
2 yellow con
2 green/blk rods
Step 10: Add to Top and Botem and Mix
its a small addition to the top part of the bow
*plz note the 2 yellow connectors in the back are not supposed be in this pic1*
pic 2 is how the bottom should look
pic 3 is when u add limb then mix
pic 4 is just the top and bottem mixed
also note that after you are done add a red piece like in pic 3 unless you want the bow to break constantly
pic 4 is that 4 orange conectors and 2 green rods u built a wile back connected to the middle red rod
Step 11: Stock Con to Bow
ok now you will start some conections from the stock to the bow itself (yay finaly)
pic 1 this thing will keep the stock straight if some weight is put on it
pic 2 this is the first conections between the bow and the stock
pic 3 the top red peice realy dose not need the half rod peice but its there in case 1 falls off and i cant find it i have spares, then there is the yellow conector with 2 green rods on bolth sides
pic 4 this is optional, you can also take a red rod and put normal small wheels in this place to
Step 12: Stringing for Power
ok now this will show you my sugestions for stringing it
pic 1: the bowstring should be a stretchy not the strongest of all rubber band
pic 2: this is were i used hairbands but try to use semi string bands here also note the band in the wheel of the limb that should be a strong band
pic 3: also you can put the rubber bands like this to keep the bow from bending down
Step 13: My Kind of Arrow
ok you are done with the bow now what? easy you make arrows!
basicly what this is is a 10 inch wooded skewer with a notch on the end and tape for feathers and tape neer the tip to add some weight on the front so it gose head down first
you might want to skip the notch for it is kind of hard but it dose not mater
ok to load it (srry dont hove a pic) you place the arrow inbetween the limb wheels and pull back all you can before the end of the orange conectors going inbetween
ty for reading this, this was brought to you by: sypran, 5 times internet not responding, 2 computer shutdowns, 3 cans of seltzer, my old cellphone and 1 crossbow
Can you believe these photos were taken by a cellphone?
    • Growing Beyond Earth Maker Contest
    • Fandom Contest
      Fandom Contest
    • Backyard Contest
      Backyard Contest
    55 Discussions
    Sypran
    11 years ago on Step 10
    ok idk y but it wont show my pic on step 10 so gust foloow what i said there
    smidge147smidge147
    Reply 11 years ago on Introduction
    i did cus one day i was sayin "i dont know to people on msn" and i got lazy of sayin it like that so i made it idk!
    Sypranwill123
    Reply 8 years ago on Step 10
    I probably do, these are old and from my old cellphone...
    atheas
    9 years ago on Step 13
    i found tht its good to but another piece of a skewer on the back for the notch
    SypranKnexFreek
    sadly no... I did make one once but it hardly worked and was to sensitive
