Ipod or Mp3 Player Hardcase From a Book
Intro: Ipod or Mp3 Player Hardcase From a Book
recycle a used/useless book into an a functional hard case for an ipod or other mp3 player!
STEP 1: Gather Your Tools and Materials
you need:
an old book, preferably hardcover, thick enough to accomodate your music player,
some white glue, elmers or equivalent,
something to hold the glue in (film canister)
a small brush to spread glue,
a box cutter, exacto knife, or other sharp tool
drill or drill press
small magnets (2)
small piece of steel (must be thin and magnetic)
straight edge or ruler
spray paint (optional)
masking tape (optional)
small magnets (2)
STEP 2: Glue Up Your Book
take your book and find what pages you want to save. even if you do not want to save any, at least save one for use in a later step. mix up a glue solution of around half glue and half water. put one of those clear plastic page protectors into the book where you want to save pages. then take the glue solution and paint it onto the outside of the book. dont use too much or the pages will warp and itll look like you got water on it. allow it to dry under something thats moderately heavy.
STEP 3: Start Cutting
take your page protector out of the book and open to the first glued page. take out your mp3 player/ ipod and lay it on the page. trace around it. if you want to line the hole with something soft at the end cut a little outside of the line. use your boxcutter to cut a hole using the line you drew earlier as a guide. make sure you are using a new, sharp clean blade, or it will take forever. you can carefully use a little force and cut a lot of pages at once. it only took me like ten minutes to cut out a hole for my mp3 player. if you want, go ahead and cut a spot to store some ear buds, like i did.
STEP 4: Add Magnets.
take the drill or drill press and drill into an unused part of the glued section of the book. insert a magnet and glue it in. do the same thin again on another part of the book. then on the inside cover glue the two thin pieces of metal in spots that match up with the magnets in the glued section of the book.
STEP 5: Clean It Up
test fit the mp3 player. if it fits well, coat the inside of the hole with the glue solution. then apply a very thin coat of the glue solution to the top of the glued section and put one of the unglued pages on it. close book tightly. when its dry, open the book and cut through the page that you just glued to open up the hole that you cut in the book. this is to cover up any marks that you made on the book or any cutting errors, as well as the magnets.
STEP 6: Paint
this is an optional step to make the book look cooler. i used a readers digest book of condensed books, so i painted it. if you want people to see what book you used, dont paint it. mask up the sides of the pages, and the front and back covers, and paint the spine. when dry, remove masking tape, then mask the spine and paint the covers. when the paint is dry, remove the tape and your done. i did mine with a flat black spine and hammered finish grey covers.
58 Comments
fraser02 8 years ago
coool as!
Alvarezmaa 8 years ago
very nice
BLR_RAVI 9 years ago
HMice 12 years ago
vruiz3 12 years ago
xXxMoDdxXx 12 years ago
vruiz3 12 years ago
judoca 12 years ago
kslatin 12 years ago
hivoltage 12 years ago
zombiet4cos 16 years ago
hivoltage 16 years ago
hmm... 13 years ago
HAL 9000 17 years ago
bwool1 13 years ago
paperclip32 13 years ago
1)If you're using water based glue,press it down with more books.
2)Dull blades cause the page to rip.
3)Ripping out the pages can also tear the page where you don't want it torn,causing a hole in the side of your book.
4)Boxcutters are neater,dremels are faster.
5)Lining the sides and inside with hobby putty lets you sand them until smooth.
Just some pointers.
xadevox 14 years ago
jaytotharrr 17 years ago
The Porsche Fan 15 years ago
https://www.instructables.com/id/Literary-Clock/
I just pressed my book to the workbench with clamps and kept on cutting, I bet I did about 64 cuts until the whole square was cut out. I cut all four sides a few times and then ripped out about 10-15 pages and the repeated that until my hole was all the way through the book.
