Introduction: Knex Door Lift Instructions
finally here are the instructions for my famous door lift. i hope it's all clear enough and good luck!
sorry for bad quality pictures
Step 1: The Base
Step 2: The Middle
the middle has two components almost the same.
Step 3: The Top
Step 4: Connect
connect the three parts
Step 5: Pushers
the pushers is the main part of the door lift.
the pushers work from both sides, the side where the motor is, and the other side.
Step 6: Connect the Pushers
connect the pushers with this thing.
Step 7: Gears and Motor
this is the part where the motor drives the door lift.
Step 8: Congratulations!
you just finished the door lift. have fun!
i hope it was clear enough.
28 Discussions
3 years ago
I'm working on a new design for this lift... Instead of the pushers being on the slider rods, I'm working on creating a cart that the pushers roll on. I think it will work with less friction and run smoother... pics soon, I hope.
6 years ago on Introduction
cool lot of pieces though. :D
8 years ago on Introduction
Awesome lift! Sadly, it doesn't work well with golf balls because they're too heavy. :(
werkt deze lift ook met big air ball tower balls
Ik heb het geprobeerd maar dat werkt niet
oke bedankt :)
Coole lift ik heb hem gebouwd en hij werkt perfect! Ik ga hem gebruiken in mijn volgende knex ball machine.
9 years ago on Introduction
do you need that motor
no you can use every knex motor that's powerfull enough. otherwise you need to gear it down.
Can I use these pictures for the Official Guide to Ball Machine Lifts?
sure, every picture you can find you may use for the guide :)
Thanks! I'll tell when it is done!
Same goes for rolling arm and parallel arm lift. (tell me if you have more lifts!)
cool!!!
very good
thanks!
Best lift ever!
thanks man!
Well-built. I like it.
thanks X)
