Introduction: K'nex Grenade
simple grenade like my other one,bot smaller and more shrapnel added.please rate.
Step 1: What You Will Need
you will need,
14 green connectors
1 white rod
7 yellow green rods connector thingy(comes with creature value tub)
yellow green eye piece
14 mini green rods
1 white circle
1 navy circle
14 green connectors
1 white rod
14 mini green rods
1 white circle
1 navy circle
Step 2: Making the Side(grip)
Give a general description of the Stepconnect two green connectors with a green rod
Step 3: Adding the Shrapnel
add the last of the green rods to one end and the yellow green connector rod thingy's tho the other.depending if you compromised with other pieces,any other ways will work.
Step 4: Connecting the Sides(grips)
slide the sides into the circles.MAKE SURE TO leave the gap in the white circle that lines up with the gap with the navy circle free(open)
Step 5: The Pin
insert the yellow eye piece into the white rod.connect that to the open gap on the white circle.DONE(unles you extend it like in picture, in which you could look at my k'nex frag grenade instructable.)
