Knex Mini Bow
Introduction: Knex Mini Bow
For my first instructable I decided to make a mini knex bow. This bow does not require a lot of pieces and is way more powerfull than I expected
Step 1: Step1: Very Simple
Make theese, if for some reason you can't tell there are eight of theese.
Step 2: Step2: Yet Again, Very Simple
Step 3: Step3
Sorry for bad pic but, I think you can figure it out.
Step 4: Step4
Place ruberband around one of the pullies, as this will be diffucult but possible later on.
Step 5: Step5: Almost Done
Put theese together so you get this,(see below)
Step 6: Step6: the Final Touches
Make this. (3 blue spacers = 1 grey) also the green rods are the same as red rods.
Step 7: Step7:done
Attach what you made in step 6.
Step 8: Step8: Loading and Firing!!!!!!!
When you load push the grey rod inbetween the orange and brown connectors in the middle. I would suggest cutting a slit in the end of the grey rod (ammo) but, be careful as shown in pic2,ouch that hurt my finger. When your done it should look like pic3 when loaded.
Be the First to Share
    • Anything Goes Contest 2021
    • Jewelry Challenge
      Jewelry Challenge
    • Raspberry Pi Contest
    39 Comments
    FrozenIce
    FrozenIce
    11 years ago on Step 8
    cool! but when firing you have to place it properly or else you will hurt your self
    dsman195276
    dsman195276
    14 years ago on Introduction
    good job. i like the look of the whole thing. generly bows are more powerful because of the shorter berral and no need for a ram.
    thekingisme
    thekingisme
    Reply 14 years ago on Introduction
    Because... Direct transfer from rubber band to projectile instead of rubberband to a ram then to the projectile.
    ooda
    ooda
    Actually, when a large object hits a small object, the small object will travel faster than the large object was initially moving. So using a firing pin will shoot harder with a well-made gun (unless the bullets are bigger than the firing pin).
    An Villain
    An Villain
    Reply 12 years ago on Introduction
    actually the ram makes it go shorter i have theoretical and practical proof because energy is lost in the transfer from the ram to the bullet in the form of sound and heat which is also lost from the ram traveling down the barrel. this is the practical proof, think of any slingshot mech gun such as the sr-v1+v2 the sipriani rifle they have good range but a gun with a barrel and ram of the same size will go shorter. but i do admire your reasoning oodalumps.
    ooda
    ooda
    An intelligent response from an Instructables Knexer? I thought it was impossible. You are right that firing pin guns are inefficient. So I guess one could argue for both sides. It depends on the gun. But generally a slingshot will shoot large ammo better, and a firing pin will shoot small ammo better.
    juneapaluna
    juneapaluna
    Yay, 1,900 views. Aww man, does that make it 1,901 now that I posted this comment :(
    machlarenF1
    machlarenF1
    13 years ago on Introduction
    this bow is the best bow in the world!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    machlarenF1
    machlarenF1
    13 years ago on Step 7
    dude thnx very powerful i made a dent in my wall with this good job!!!! best bow on website!!!! thnx very much!!!!!!!!!!!!
    skaterwhoowns
    skaterwhoowns
    i got an ouchie too, in exactly the same spot. Its not pretty, blood gushing one. Pfft yeah right bt it hurts like a mother F***
