Introduction: Knex Rbg Rifle
this rifle is my own design except for the trigger which is from the gun Gunzo the great. This gun is semi auto. The piece count is
rods
green- 19
white- 20
blue- 12
yellow- 4
red- 8
connectors
gray- 38
orange- 10
red- 12
green- 15
yellow- 8
white- 9
special
blue spacers- 18
tan connecters- 2
note to whoever builds this
one silver spacer equals 3 blue spacers
rods
green- 19
white- 20
blue- 12
yellow- 4
red- 8
connectors
gray- 38
orange- 10
red- 12
green- 15
yellow- 8
white- 9
special
blue spacers- 18
tan connecters- 2
Step 1: The "Buisness End" (triger)
the trigger system
pic 1. is a side view of the gear box
pic 2. is a top view there are 4 blue spacers on the blue rods in between the 2 sides
pic 3. is the cog that holds the rubber bands. make all the parts and gather them
pic 4. is the trigger make all the parts and gather the loose one
pic 5. is the trigger in a different view
Step 2: Assembling the Triger
pic 1. slide the cogs thru rod partialy through the hole in the connecter
pic 2. slide on a blue spacer
pic 3. slide the cog on then follow it with a blue spacer then push the rod all the way through
pic 4. cap off the rod with a tan connecter
pic 5. get the trigger
pic 6. slide it so the triggers holes are lined up with the circles holes
pic 7. slide the trigers thru rod through the holes
pic 8. cap it off
hooray the trigger area is done
pic 8. cap it off
Step 3: The Butt of the Gun
build it and connect its self explanitory
there are 2 veiws for you dont build 2
Step 4: The Barrel
very confusing pay atention
pic 1-2. 2 veiws of the same part
pic 3. get these
pic 4-5. 2 veiws of the same part
pic 6-8. 3 veiws of the same part
pic 9-12. how to assemble the barrel
pic 13. pull the white rod out
pic 14. attatch the green peice
pic 15. attatch the rest of it
pic 3. get these
Step 5: Attatching the Barrel
follow the pictures
pic 1. get the barrel and gun
pic 2. atatch them like so there is no connection at the bottom just the top
Step 6: The Strength
pic 1 there are 15 grays on each
3 blues equal a silver spacer
pic 2 there are 5 greens on each
Step 7: Adding the Strength
pic 1. get the peice
pic 2. connect as shown yes it connects into the bottom half circle
pic 3. do the same to the other one
pic 4. make sure it is connected were zoomed in
pic 5-6. connect both as shown the red is in front of the white
Step 8: Adeding Some Detail and a Low Amount of Strength
follow the pictures
pic 1. get these
pic 2. add this
pic 3. cap it off
pic 4. do the same to the other side to
pic 5. top veiw
pic 6. add that part there
pic 1. get these
pic 2. add this
pic 3. cap it off
pic 5. top veiw
Step 9: Ruber Band Placement
pull the ruber band allong the barrel to start then follow the pictures
Step 10: Loading and Fireing
dont over load this gun with those fat ruber bands
pic 1 place the ruber band here
pic 2 pull it to the first cog
pic 3 pull the cog back one click and load another band
pic 4 what it should look like
dont put more than 5 bands
your done now go have fun and oh mods are welcome and dont hurt anyonne im not responsible please rate
enjoy
enjoy
