Introduction: Knex Rifle
this is just a normal rifle it has a true trigger very powerful and average accuracy really good gun
Step 1: The Barrel
1.make 13 of these i accidently put 14
2.join them like so
Step 2: The Trigger
1.make one of these
2.and one of these
3.make these 2 pieces
4.put all together like so
5.join onto the barrel
Step 3: The Handle
1.put 11 green connectors on a yellow rod
2.put another yellow rod through the hole
3.connect it to the trigger and barrel and dont forget the white rod on the end with the 2 blue rings
Step 4: The Rubber Bands Firing and Loading
1. put some small rubber bands around there
2.then put them on roughly the 4th blue rod depends on rubber bands
3.hold the rubber bands on the end with a green rod look you can use broken ones
4.this is the bullet you can sharpen it if you want but it will only work close range if you want long range use a smaller rod and/or replace the orange connector with a yellow one and a white rod like on the carbine
5. loads like so
