Knex Rod Launcher
Introduction: Knex Rod Launcher
this was made at my friends house. he improved it a little. it will shoot about 30 ft and is very accurate. this is my first instructable. enjoy!!
p.s. the instructions are very accurate and easy to follow.
Step 1: Materials
these are the pieces. not to many.
Step 2: Step 1
pretty easy folks!
Step 3: Step 2
this is tricky.
Step 4: Step 3
sorta hard.
Step 5: Step 4
only put in 1 of the blue rods.
Step 6: Step 5
now add the second set of rods.
Step 7: Step 6
now put on the 2 semi-circle yellows, and flip it upside down.
Step 8: Step 7
add the blue rod and flip back over.
Step 9: Step 8
now add the rubber band around the barrel (greens).
Step 10: Step 9
slip the rubber band in between the 2 blue rods. make sure it is pointing down, and make sure the smooth side of the barrel is pointing towards you.
Step 11: Step 10
put the rubber band in between the first groove from the top and the second.
Step 12: Step 11
slide the gray rod through the greens and the circular whites, pull back untill it almost comes out with the rubber band on the back, and fire at will. (this is not a exuse to fire at your brother "Will".)
note:i am not responsible for any injurys caused by this instructable.
Be the First to Share
    • Anything Goes Contest 2021
    • Photography Challenge
    • Raspberry Pi Contest
    16 Comments
    wussap
    wussap
    14 years ago on Introduction
    whats next? knex scissors? knex pencils? knex chopsticks? cmon.......
    Knexman2020
    Knexman2020
    meh.... I made a knex rod shooter with only 3 parts. 2 knex ball halfs and a thick stubby rubber band. It could e-z-lee go threw a thick water bottle if the rod was sharpened. But no its on my roof... You can also use a wheel and a shorts stubby rubber band to get the same effect.
    ooda
    ooda
    Reply 14 years ago on Introduction
    Worse, no trigger at all lol.
    flames10391
    flames10391
    but its still not a block trigger but then again, what could be worse than a block trigger? nothing is worse than a block trigger
    ooda
    ooda
    This gun is just a bunch of connectors on 2 rods... Worse than a block trigger.
    flames10391
    flames10391
    but you don't see many like this on instructables, mostly block trigger/killerk ripoffs/ micro knex guns made of like 3 pieces that shoot a few inches
    neoplayer2
    neoplayer2
    The ONLY thing worse than a block trigger K'nex gun is a K'nex gun that doesn't shoot at all! Sadly, I've made a few nonshooters myself :( (Mostly failed guns, lol)
    Danny
    Danny
    Hahahaha, the amount of negative comments there will be makes me laugh! also learn to use the reply button
