Introduction: Knex Spider Splatter Sorry George
this is the first little gun i have posted all the guns i have made before have been very powerfull you will be suprised at the power this gun can be made to do it fires about 35 ft with 3 elastic bands made smaller by twisting them i am not getting sued by any spiders you injure with this gun rofl
pros:
good range for size
hurts when fires at little brothers
ammo never ever jams impossible
cons:
makes the right thumb sore from the trigger being in the top of the gun
sometimes the trigger jams
but other than that it is a very good little gun
pros:
good range for size
cons:
Step 1: Parts List
these are the parts you will need to collect not a lot of parts need dont worry just look at the notes the rubber bands dont have to be excact
Step 2: The Barrel
this is very easy to do i will give you some advice dont just put the connectors on one rod put them on bot at the same time it is easier
the parts go like this listen carefully from the rear end it goes
red 1 quarter moon x6, then yellow half moon x1then on the left red rod it is a grey half ladder pointing in wards slightly to line up with the bottom of the yellow half moon connector, then on the same rod a triangle with the hole lined up with the others then red 1 quarter moon x8 then a half moon x2
Step 3: The Trigger
this step is very easy to do get the trigger from the parts mound and add it to a red rod put the spacers as i show you and repeat on the other side just without the trigger
Step 4: Adding the Rubber Bands
grab one rubber band and twist it twice like you would with a bobble and add to the trigger as shown then grab the other 3 rubber bands an twist twicethen put on the ram rod as shown then you are done dont kill george please !!!! aaarrrggghhh he is so scary he is sat on my hand eeewww
