Least Cost Outdoor Stove
Intro: Least Cost Outdoor Stove
it's really easy to build a stove for use out- or indoor.
This one is very lightweight and easy to use.
It tooks only two minute to build and the weight is about 10 gramm.
STEP 1: Candle Lights
you need two candle lights
STEP 2: The Cups
take away the candles, we need just the cups
STEP 3: Fold
We have to fold one cup in such a way that it becomes little smaller on the upper side.
We can use a tang or just your fingers. One or two millimeters are enough.
STEP 4: The Burner
Put a piece off clothes in the smaller cup.
You can take a piece off your old jeans or something else but take no syntetic.
STEP 5: Close the Cups
We must put both cups together and they should fit smooth.
STEP 6: Cut
Now must we cut some hole in the upper cup.
First smal holes on the outer circle and then smal holes on an inner circle.
Finally cut two lines in the centre.
Open the four triangle in the middle.
STEP 7: Use
Just fill some Tenol or methylated spirits in the cup and light the fire.
The stove will heat two cups off coffee or soup for you easily.
Never use gas or other stuff, only methyated spirits.
51 Comments
IdahoDavid 16 years ago
the gizmoman 16 years ago
mondaymonkey 16 years ago
mkslocomb 12 years ago
blodefood 15 years ago
benhudson 16 years ago
Estwald 15 years ago
chuckr44 15 years ago
Broberg 13 years ago
KittyF 13 years ago
SurvivalTopics.com 16 years ago
KittyF 13 years ago
amniup 14 years ago
just to share some experiments I've done... this is a variation of the stove: only one ring of holes, only 10 holes, and the central large "cross" hole is folded INSIDE so I can put a coin over it after filling with alcohol.
Put some alcohol over the coin to speed up lighting
Well, it probably is the simplest "penny stove" clone ;-) with a nice flame pattern
And, as the flame never go inside, probably cloth padding will last more
amniup 14 years ago
I've done some modification:
- I've done the small holes with a push-pin: faster & better holes
- I've put the top cup INSIDE the bottom cup, because in the original project some little flamed alcohol leaked from the "folder" near the bottom, now it's ok
- I've used rockwool instead of piece of clothes: the flame I've got seems a little more "pressurized" than the one in your photo (but I'm not sure it is for this reason...)
- Lighting it from the top require 2-3 minutes in order to get the stove to full power; it will go to full power in few seconds instead if "primed" wetting the bottom of the stove with few drops of alcohol and then lighting them
Performance:
- I can fill it with max 14 gr of ethilic alcohol (half ounce), with this amount of alcohol it will boil half liter of water in 9-10 minutes, and die a minute later...
Conclusions:
- Really smart and simple-to-build micro-stove! ;-)
Side note:
- I'd like to build a so-simple stove with little more capacity to make more complex "cooking" with it, but don't know how to find similar but bigger cups, and don't want to use a can-stove; ...any idea?
