Loomband Keyboard
Introduction: Loomband Keyboard
About: Hi! I am a pasonite photographer (beginner). S4, and I love to make things! if you have any questions don't hesitate to ask! EDIT I love Star Trek (any of them) and I want to become a Navy engineer, Any how iā€¦
Today we are going to make a loomband keyboard charm. :-)
It came across when I was experimenting a few different charms to make. I will also put them up too, but lets get started!!!!
Step 1: What You Need
You will need:
6-White bands
4-Black bands
24-Pink bands
1-Pinky or see through band
1-Random band
A loom
A hook
Step 2: Starting
Start with double pink bands then put them at the top of the loom on one side then the other side (still double bands).
Step 3: Adding the Keys
Get two white bands and double them and then put at the top joining the pink in the dobble then the same for the black but under the white until you get something like this.
Step 4: The Sides
Still using double bands get the rest of the pink bands and go down each side, but stop when both sides are one peg above the end of the black and white strip then cross over. Like in the picture above.
Step 5: The Cap Band
Get a single pink or see through band an at the bottom of the loom bands and rap it around 3 times.
Step 6: Looping
Ok, first get the hook and start under the cap band and hook the first 2 bands and pull through and place on the peg that it goes to and do the same for the other bands like in picture 2.
Then loop up the middle like in picture 3.
Now you can do the out sides up to the top like in picture 4.
Step 7: Adding the Hanging/holding Band
Now we can get the holing/hanging band in place!
So what you need to do is at the opposite end of the cap band stick the hook through all the bands and put a random band on the end of it and pull it through , so that half is at the bottom and half at the top, then take the bottom band and pull it through the top band and pull. Now you should have a not and thats that part done.
Step 8: DONE!!!
Now pull it off and thats you done!!! Adjust if needed!
Homemade Gifts Contest
Be the First to Share
    • Anything Goes Contest
    3 Comments
