Magnetic Push Pins
Intro: Magnetic Push Pins
Push pins are usually used to pin notes to a cork board. it's aesthetic and organized, but a magnetic board is (in my opinion) more so, and it's safer for kids etc.
I, personally, like a clean and uniform design. I don't like a refrigerator full of weird magnets, but sometimes you gotta hang something on there (e.g. shopping list, a note for a roommate etc.), so i thought " i wish i could use something like push pins instead of all those food delivery magnets" and then it came to me - why not use push pins?
In this instructable i will show you how to make magnetic push pins to use on a refrigerator, steel door or magnetic board.
I hope you enjoy this simple, short and fun one.
STEP 1: Materials and Tools
1. push pins
2. neodymium magnets (a.k.a earth magnets) the same diameter as your push pins. (the same number as your push pins)
3. Epoxy glue
4. dremel with a diamond cutter or grinder bit
5. wire cutters
3. Epoxy glue
5. wire cutters
STEP 2: Circumcision
we need a flat surface, for that we need to remove the metal pin.
(USE SAFETY GEAR)
i recommend using a wire cutter to make the initial cut as close to the base as possible and then grinding the rest with the dremel.
i tried cutting the metal pin with the dremel but the friction caused the metal to heat and melt the plastic around it (not a big deal but makes things harder)
i recommend using a bench vise to hold the pin in place while grinding.
(USE SAFETY GEAR)
STEP 3: Glueing
mix the epoxy components, glue the magnets to the pins and let it dry completely.
the remainder of the metal pin still in the plastic will stick slightly to the magnet and help keep it aligned.
you need very little glue, don't put too much on there because it will just ooze down the sides.
use a metal surface so the magnet will not move, preferably a flat horizontal surface.
the polarity of the magnets does not matter.
enjoy :)
enjoy :)
23 Comments
Yonatan24 8 years ago
Looks really nice, Did anyone ask you why you were "sticking push-pins in you refrigerator"? ;)
jimmysymo 10 years ago
GOOD FOR YOU.(Ashkelon.)
zamrin 10 years ago
Link-tC 10 years ago
tjesse 10 years ago
flyingpuppy 10 years ago
harari 10 years ago
you can choose the thickness according to how strong you want the magnets to be
MrRedwood 10 years ago
yellowcatt 10 years ago
londobali 10 years ago
Thanks for sharing..
Carafe 10 years ago
harari 10 years ago
bottle cap magnets sounds pretty cool, i smell a new instructable.. haha.
cnegrea 10 years ago
Penolopy Bulnick 10 years ago
cspann560 10 years ago
okamotos 10 years ago
1. Just get a lighter and heat the tip for a couple seconds, then use a pair of pliers to pull it out (or if you're daring, maybe a towel or tissues). Depending on how long you heat it, the plastic may pull out a bit - just tap it down on a hard surface.
2. Buy magnets from eBay or Amazon. I bought 3/8" x 1/8" N42 and the diameter is perfect.
3. Use a few drops of SuperGlue - just be careful to let it dry completely to avoid getting it on your fingers.
harari 10 years ago
yukikkt 10 years ago
NTT 10 years ago
