Make a Joule Thief Easily
Intro: Make a Joule Thief Easily
white or blue led lights at almost 3 volts.but by using joule thief you can run leds at even 0.5 volts.but in this instructables i will be using 1.5 volt battery.you can use the last bit of energy in the battery using this circuit.i am not good in electronics but even i could do it because it is easy.using this you can reuse dead batteries and help in greening of earth so lets start..its easy and great for scientific classes and experiments.
STEP 1: Things You Will Need
1)some thin wire.
2)a white or blue led.
3)a 1000 ohm resistor.i got mine from a toy.so leads are small.
4)any npn trnsistor-1.(but transistors like 2n3904 or 2n4401 or bc337 etc are good choice)but if you use pnp transistor you will have to reverse the polarities.
5)a ferro magnetic core like toroids.if you dont have toroids then take the circuit of a decreased fluorecsent bulbs .there you will see one type of round nut wrapped in wire.there you have your toroid.
6)an aa battery
tools you will need:
soldering iron or pliers
beside the things picture you may see white dots.those are reflections of flashlights.
STEP 2:
STEP 3: Wrapping the Toroid
STEP 4:
STEP 5:
STEP 6:
STEP 7:
STEP 8: Troubleshooting
if your joule thief does not work then check the following things:
1)check whether the wires around the toroid are broken or not.if broken replace it with new one.
2)check whether the poles are right.
3)you may try by not using the resistor .my one worked by not using it.
but even after these if your joule thief does not work then it is bad luck.
i hope you liked these instuctable.feel free to ask any question .i will try to answer according to my ability.
i dont know english much as it is not my mother tongue language.and so if any mistake help me find it.give some more ideas.feel free to ask questions.i will try to answer them as much as possible for me.bye!have a nice day
11 Comments
ManuelaM14 6 years ago
mohd hashir 8 years ago
PrithviD 8 years ago
what's the role of the transistor in this circuit ?
abinajayakumar 10 years ago
AH Electronics 10 years ago
Rajat Uppal 10 years ago
Solderking 10 years ago
Lectric Wizard 10 years ago
