Make a Non Functional Gas Mask
Intro: Make a Non Functional Gas Mask
with some googling I found this site
http://john.curtin.edu.au/education/gasmask/index.html
and they have a tutorial on how to make a gas mak out of paper , ect. well I thought it could use some work. so I went in my workshop and found things to use!
STEP 1: The Design
I found this download, that is the design layout. I first made the eye covers out of plexy glass by cutting them into squares then sanding the edges.
STEP 2: Side Cylinders
I used 3" pvc for thesejust cut the m to the size desired. for the middle I used a 2" pvc end cap and just drilled holes in it. then I made a plexy circle the size of the 3" pvc and drilled holes in them. on the other side of the cylinder another circle piece of plexy just with a large hole so the 1 1/2" pvc will fit and slide in then I just glued every thing together to make 1 piece.
STEP 3: Put It Together
in order for the cylinders to fit on the middle piece you need to grind/ cut off some pieces (see picture. after you do that take out you hot glue gun and glue the 2 side piece to the middle piece
STEP 4: Glue, Glue, and More Glue
for the face part I used an old plastic ball the kind you would find at wallmart in the tall racks in the toy section. then just cut to the design on the download. then I gleu the mouth hole to the middle piece of the pvc build.
STEP 5: Finishing Up
I used large red rubber bands to hold the mask on my face. here is My end results. I will remake the face part and I will update!! now go join the umbrella corporation!!!
44 Comments
Egret03 7 years ago
i might try this for my Halloween coustume, i going to be "mother war" from my chemical romance's concept album the black parade.
mrtwitchy909 13 years ago
Fart burst 11 years ago
SNiPERSeyes 13 years ago
slimguy379 15 years ago
dp mac 14 years ago
bustedit 15 years ago
bowmaster 14 years ago
Vulcanator 14 years ago
red-king 15 years ago
sh0ckl473 14 years ago
ze pyros a spy
red-king 14 years ago
countrygiri 14 years ago
tentacle 15 years ago
lop145 14 years ago
knexdude152 15 years ago
mr. cool 384 14 years ago
daelans 15 years ago
