Introduction: Make Your Power Supply to Fit in a Full Power Strip
usually when your power strip is full
u cant add a lot of power supply so this will help u
Step 1: Tools U Will Need
Step 2: Get the Head Off
start by removing the head using a saw
Step 3: Clean Things
first clean the table then remove the heat-shrink tubing
Step 4: Make the Holes
u need to make 2 holes at the front of power supply use your solder or a drill
Step 5: Connecting the Head
put 2 short wires in the holes you just made and solder the wires in the head connectes
Step 6: Hot Glue
fill the head with hot glue and place that as u see in the photo
Step 7: Finish the Connection
connect the wires with the transformer inside the power supply and secure them with hot glue
Step 8:
find a pease of plastic and cover the hole don't forget to add hot glue
Step 9: Finish
all done now
Step 10: One More Step
u can use this to repair other power supply heads
2 Comments
7 years ago on Introduction
That's cool that you can hack that plug. Thanks for sharing! I hope we see more from you on Instructables in the future!
Reply 7 years ago
thank you. I'm making some projects so stay tune. ?
