As the first figure shows, please choose the servo with the longest axis. Please pay special care in each servo installation because servo can only rotate 180 degrees instead of 360 degrees. Necessary screws:
1) 8mm x 2
Step 4: Left Arm
Please attach the stick and rotate the servo clockwise until it stops. Then fix the stick as the last fourth figure. Necessary screws:
1) 12mm x 3
2) 8mm x 2
Step 5: Right Arm
Please attach the stick and rotate the servo clockwise until it stops. Then fix the stick as the last figure. Necessary screws shows:
1) 12mm x 3
2) 8mm x 2
3) 6mm x 1
Step 6: Left Arm + Chassis
Necessary screws:
1) 12mm x 2
2) 6mm x 1
Step 7: Right Arm + Chassis
Step 8: Middle Column
Step 9: Merging With the Base
Please attach the chassis to the base, rotate the servo clockwise until it stops. Then fix the servo on the base as the last figure shows.
Step 10: Branch 1
Necessary screws: 6mm x 2
Step 11: Branch 2
The number of the branch is 2. Necessary screws:
1) 8mm x 1
2) 6mm x 1
Step 12: Last Servo
Necessary screws: 8mm x 4
Step 13: Gripper 1
Necessary screws: 1) 8mm x 1
2) 6mm x 3
Step 14: Gripper 2
Rotate the servo clockwise until it stops and fix it as the last second figure. Rotate counterclockwise a little bit to connect the stick and the gripper.
Step 15: Attach the Gripper
Step 16: Add the Control Board
Please pay attention to the color of the 4 servo cables. The yellow color is adjacent to the arm. The coffee color is next to the joystick.
Step 17: Trouble Shooting
1) Why does the LED on the joystick board flash? A) The LED just lights up normally. It flashes when the board reboots. The reason is that there is too much current on the board. It may cause the servo angle to get out of range, as the screw is driven too tight.
B) Solution: Loosen the screws in each joint. Disconnect all the servo cables and reconnect them one by one. Please also check to see if you are following this manual when assembling the servos.
For any problem, please email me at ted99 at gmail.com or add me as friend in FB. (Ted Lien)
Building a me arm, I think power is a huge problem, most servos will reset the arduino if driven directly from the 5v supply of the arduino.
I am planning to update the board and schematic to add additional servos, and the ability to add a seperate source of power for the servos, which can power the arduino.
very good. but i want to make it by arduino+2 joystick+nrf24l01 (radio control). can you help me. i need the arduino code for control 4 or 6 servo by arduino+2or3 joystick+nrf24l01 (radio control) .
Does anyone know why do we use ports 12 & 13 on the Arduino Sketch, under the instruction SoftwareSerial mySerial(12,13); if there's nothing connected to those pins? :)
Where did you purchase the shield with two thumb joysticks? I'm mostly seeing shields with one thumb and four push buttons. Can I add another thumb joystick in place of the buttons?
Hi there! Does anyone know where I can get the joystick control board? I've been looking around online but I've not found anything yet. Appreciate the help, thanks!
11 Comments
9 years ago on Introduction
Very cool! Thanks for sharing these instructions. They look very easy to follow for anyone assembling this neat looking kit.
Thanks and it's great that you like it.
Question 5 years ago on Introduction
What is the power supply used along with this joystick module?
8 years ago on Introduction
Reply 5 years ago
my email : amin.zareasl@gmail.com
5 years ago
7 years ago
Thank you for making this tutorial!
7 years ago
How to buy it?
The shield is customly made for MeArm.Joystick. You can find circuit diagram on top of this post.
