Modified (but Still Awesome) Pea Shooter 2
Intro: Modified (but Still Awesome) Pea Shooter 2
this is my fist instructable so dont yell if its not perfect! its basically a modification of an existing constructable which i made bored as ever at skool
hope u luv it!!!
hope u luv it!!!
STEP 1: Materials Needed:
you will need
rubber glove
bottle (small water bottle will do)
scissors
pea or similar sized round object
rubber glove
scissors
STEP 2: Assembly
first the neck and the curved area around it needs to be cut off the the main body of the bottle. then cut a finger (as apposed to a balloon)off the glove and stretch it as far as possible down the neck after taking off the ring that is so often on the neck (you can use this for holding on the finger of the glove while firing).
then put the ring onto the neck over the rubber (duct tape is another method 4 keeping it on if u want to be sure.
STEP 3: Firing
to load, hold the shooter with the open end facing you and drop in your choice of ammunition and point the open end away from anyone within30ft of u! then gripping the projectile pull back the glove finger and ... let go! the distance you can pull back depends on how far u think u can without it snapping!
STEP 4: Almost There!!!
FFFIIIIIRRRREEEEEEEE!!!!!
6 Comments
potez 14 years ago
elnino 15 years ago
and63 16 years ago
supersaddy 16 years ago
!Andrew_Modder! 16 years ago
iKill 16 years ago
