Introduction: Motorcycle Toy Model With 2 Units of Gas Lighters
Do you like toys? You may want to work on a car model kute like this !? Please follow the instructions below hidden:>
Prepare NVL toy motorcycle makes 2 units of gas lighter with gas leaks Clean It Out (because otherwise it will explode doing), glue.
Step 1: Drain-away
- Step 1: You took out the details after 1, 2, 5, 6, 7, 8 each of 2 . Particularly detailed 4 1 the material is removed, the other goes off the plastic tube. Details 3 then just take 1 only.
Step 2: Step 2
Step 2: Integrating detail 1 detail 2 do 2 pair then attached to the frame like the motorcycles used as toys.
Step 3: Step 3
Step 3: Attach the details up front to do the first 3 cars. Rùi rod cage in springs 4 5. Then, cross rods through the holes in the top 4 Detail 2, then blend to the 5 remaining springs and cut away plastic rod 4. Attach the 4 remaining details on the first and second plastic rod bent a little later.
Step 4: Step 4
Step 4: Insert the details of the number 6 in Figure 7. It already attached to the back of the chassis to have 2 toy motorcycle exhaust.
Step 5: Last Step
Done
