Introduction: No Sew Nes Controller Wallet
another reinvention of this gaming classic
Step 1: You Will Need
one sacrificial Nes controller
small phillips screwdriver
wire snip pliers
UHU glue
Long Zip
Step 2: Kill a Controller
unscrew controller backing (a couple of to screws may be immovable, if this is the case remove as many as possible then carefully pry apart the controller and snap the screw mounts)
remove circut board and wire. using pliers snap off any of the screw holders/wire guides etc
leave the ones that hold the button pads in place
Step 3: Try Not to Stick Your Fingers to the Poject...
use a blob of glue to secure the rubber backing of the keys so they dont fall out -repeat for each key
Step 4: Stick the Zip
this step is kind of fiddly, try to get a zip that is at least long enough to go around 3 sides of the controller. use a piece of ribbon or similar to bridge the gap along the bottom (to form hinge).
(for some reason my browser isnt letting me create notes on the images so i hope this makes sense)
glue around the inside edge of the controller and attach zip, use an old bank card to press the zip to the edge. work out which way round you want you wallet to be and make sure the middle of the zip is at hat side (see second photo for correct way round!). glue around the inner edge on the back plate and line up the zip, sticking as much as you can before unzipping (helps lining it up) finish positioning zip.
glue a strip of ribbon around the remaining edge then to the other plate. agin use the card to press the edges in.
Step 5: Finshed!
tidy up any loose edges with a little extra glue where requred. make sure it has properly dried before using.
my entry to the Wallet competition, was a abit last minute as my first design didnt work...
my sewing machine broke part way in, hence the no sew aproach.
my original plan was similar to the cassette tape purse pictured
The Instructables Book Contest
83 Comments
8 years ago on Introduction
oh lord. i love it!
10 years ago on Introduction
Loved this will go on my to-do lists for 2013
sir i am afraid your genius is showing!
and here i am searching for a cheap nes controller. ughh
14 years ago on Introduction
Is there anyway to this and still manage to have a working controller. That would be sweet
Reply 14 years ago on Introduction
i guess u could... u would need to make a lining to hold the circut board in place also there would be a long cable to deal with but not impossible if u make it post a picture!
That shouldn't be hard to keep this circuit board in place but for the cord I was thinking of something retractable like some of the newer iron that retract so the cord wont be all over the place
That would be cool! I think you should make it. All in favor?
Win Guy
10 years ago on Step 5
These look extremely profitable! I recommend jumping on that or at least patenting the idea. Love them
I don't know if it was with permission or not, but this 'ible has been plagiarized word for word here:
http://reviews.ebay.com/Make-your-own-Nes-Controller-Wallet-Very-Simple?ugid=10000000006908904
it was without permission, thanks for the heads up :)
11 years ago on Step 5
I'm not sure I understand that bottom? Does the controller close up with the zipper inside or....?
Reply 11 years ago on Step 5
the zip i used was short so only long enough to go around three edges. i used a piece of ribbon glued in place to make a 'hinge' along the bottom edge.
hope that helps
11 years ago on Introduction
This is cool, but I wouldn't feel okay about destroying a perfectly good NES controller - those things are ANCIENT, you know! Do you have any idea where I might be able to find an imitation shell?
Thanks,
Win Guy
Reply 11 years ago on Introduction
i imagine an 'imitation' shell would probably cost more than the garage sale price tag of the old controller. but i guess u could cast a replica if you had an original to work from. it was mainly an art/recycling project using found material and plays on the iconic look of the controller. thanks for looking and taking the time to comment
15 years ago on Introduction
Very nice....! I'm a man myself and I always carry a change purse, so what?
exactly. when my friends ask me why i carry one, i just stare at them.
lol nice
Me too.
ME GUSTA!
