Office Supply Catapult, Goes 35 Feet!!!
Intro: Office Supply Catapult, Goes 35 Feet!!!
What you need:
- 10 pencils
- at least 14 rubber bands
- strong string
- bottle cap
- scissors
- something to make a hole in the bottle cap
Also please remember to vote for me in the office supplies contest.
- 10 pencils
- strong string
- bottle cap
- scissors
STEP 1:
Do what the picture shows.
STEP 2:
This is the the next step. also use more than one rubber band if you want to make it stronger.
STEP 3:
Make a square.
STEP 4:
Do this.
STEP 5:
Make a slanted square on top.
STEP 6:
Put this on.
STEP 7:
Put the other pencil on and tie the string on the bottom.
STEP 8:
Cut one of the rubber bands.
STEP 9:
Tie the rubber band around the two front pencils.
STEP 10:
Put the last pencil through the string.
STEP 11:
Wind the pencil up in the string
STEP 12:
Push the pencil up through the string and place it behind the rubber band.
STEP 13:
Make a hole in the bottle cap big enough so the pencil can fit in.
STEP 14:
Now push the pencil into the bottle cap. Now your finished! Hope you have fun! You can also slide the string back and forth along the two side pencils to change the angle of the catapult, and the farther you wind the pencil in the string the farther it will go!
12 Comments
hannahhawkins 6 years ago
jeremiahc30 7 years ago
Use half of an Easter Egg instead of a bottlecap. Much easier
AjayR2 9 years ago
i just tightened the stick i put in the string and it shoots even further.
A helpful tip : instead of putting a hole through the bottle cap to attach it, just tape it ( it is easier and works just as good).
LovelyMeA 7 years ago
How do you tighten the stick?
Instructableapprentice10 8 years ago
here is the link:
http://www.amazon.com/Mini-Weapons-Mass-Destruction-Implements/dp/1556529538
well, you could just use a plastic spoon. but that works out too! you should get this book called
Mini Weapons of Mass Destruction: Build Implements of Spitball Warfare
AjayR2 9 years ago
the instructions were also very clear!!
AjayR2 9 years ago
I Made it!!!!!!! It came out awesome. I did one modification though; I made mine with popsicle sticks. I had to apply masking tape to the corners to strengthen it. A helpful tip: put a small piece of wood of popsicle stick (or anything small) and use that to twirl between the string, then tape or glue on your catapult arm(a pencil or popsicle stick).
RoccoD 9 years ago
did it er um '-' sorta
Crazy2dragons 10 years ago
very good and easy instructible but i don't now why mine looks like a duck
D:
Penolopy Bulnick 11 years ago
Kiteman 11 years ago
