Introduction: Painting Abs Baseball Helmet
My first attempt to paint a baseball helmet and what I learned along the way
Step 1: Prep for Painting
Prep for painting
scuff with 100 grit sandpaper and clean off dust and grease with isopropyl alcohol
Step 2: Masking
mask off air vents and inside foam
push down tape hard to prevent paint leakage (look at photo 4)
Step 3: Painting
paint carefully do light even coats and do not touch paint wait 5-10 min between coats
things that ruin paint
-rolling helmets the helmet only stay in like three positions
-wiping runs pulls off all layers of paint
-gloves touching wet paint
-thick coats that cause runs
Step 4: Mask Off Other Half
mask off and scuff with 100 grit sandpaper other half of the helmet
I painted over half the first time to have no gaps
Step 5: Paint Other Half
the blue took way less coats than the yellow
Step 6: Clear Coat
be careful not to remove tape too soon see photo 2
then apply clear coat with light layers about 5-10 min between coats
clear coat gets rid of textures such as glove prints and makes everything look better
Step 7: Stencils
I tried to make a stencil and it worked with one kind of paint I had but not with the one I was using
always check on a piece of cardboard first
Step 8: Finished Product
Step 9: Final Thoughts
Thank you for reading my first instructable and I hope it helped
if you have questions email me at r.a.t.s.fixing@gmail.com and I have a youtube channel ragingattechsupportfixing
https://www.youtube.com/channel/UCbtwbKunsP_iOUjGuwKTeNw
