Pannier Organizer (ver. 1)
4,135
41
8
Introduction: Pannier Organizer (ver. 1)
Lately I've been experiencing a low-grade frustration with my bicycle pannier which  has turned into a bucket-o-chaos.  This instructable will document my first attempt to straighten it up a little.
Step 1: Materials
cardboard
remnants ($2.50)
stretch elastic ($2.79)
sticky a** glue
measuring tape
clothespins (as clamps)
sewing machine, thread
Step 2: Stiff Interior
cut out a cardboard shape that will fit inside the interior of the pannier.
I cut three such shapes out and glued them all together with wood glue.
Lay the glued boards down on some place flat, like the floor, lay a heavy object on top of that to keep it flattened while it sets up.
Step 3: Fabric Shell
create a fabric envelope for the cardboard interior by tracing around the outside of it onto the remnant.
Add a half to 3/4 inch margin all around to be the seam allowance
Step 4: Elastic Grabbers
I felt like improvising on this without a plan.  I decided to give it elastic stripes on one side which could be used as arbitrary grabbers for this and that.
Cut out strips of elastic to go along one side.  I alternated the elastic with one inch of exposed stripes, measured out with a ruler.
Attach the elastic to the seam along one side where marked.
Stretch the elastic across, lining up the ends with the markings on the other side seam.  Sew those down.
Step 5: Pockets on the Other Side
I went with some haphazard pockets on the other side with no regard for regularity.
Attach those to the side seams
Step 6: Sew Thick Envelope Together Carefully
Slowly sew the thick envelope together at the seam.
Invert rightside out
Try fitting the cardboard into it.
Step 7: Finish Outer Seam
next time, I will find a way to put the finish seam on the bottom.  I had a hard time getting a cosmetically acceptable finish on this seam on top here.  I ultimately glued a strip of fabric over it and went with that.
Step 8: Test Drive
test it out for general usability...
it's okay, but I have a better idea...
Be the First to Share
    • Holiday Decorations Speed Challenge
    • Plywood Challenge
      Plywood Challenge
    • Battery Powered Contest
    8 Discussions
    Sexybeast91
    Sexybeast91
    9 years ago on Step 4
    This iz soooooo cool!!!!!!!!!!!!! U would b famous if u sold this!!!!!!!!!!!!!!!!!!!!!
