Paper and Soda Bottle Rocket Launcher
Intro: Paper and Soda Bottle Rocket Launcher
This is a simple and inexpensive alternative to estes rockets. I wanted to do something to allow my kids to play with model rockets, my concerns were that estes rocket motors are highly flamable and the kids could only play with them if my wife or I were around. Another factor was the cost. The smallest Estes motors run about $5 for 3 motors, not a lot of fun with a yard full of kids.
We made a paper rocket launcher that used compressed air. This meant that rockets were cheap (1 piece of paper for the body and part of a piece for the fins) and safe. After several weeks of playing with the paper rockets one of the kids grabbed a soda bottle and stuck it on the launch tube and the rest is history. For hot summer fun soda bottles and water make this a real blast of wet wild fun.
STEP 1: The Parts List
1 - 1" inline sprinkler valve
2 - 2" PVC pipe 18" long
1 - 1/2" PVC pipe 18" long
4 - 1" PVC Pipe 2" long
2 - 2" PVC Elbow
2 - 2"X1" PVC reducer
1 - 1" PVC T
2 - 1" slip to 1" Male Thread PVC fitting
1 - 1/2" slip to 1/2" male thread PVC fitting
PVC Glue
Lauch handle parts list
1 - 1.5" PVC pipe 4" long
2 - 1.5" PVC Cap
6' 2 conductor 18 or 20 AWG wire
1 - Momentary switch
1 - 9v battery connector
1 - 9v battery
Total cost around $40
2 - 2" PVC Elbow
1 - 1" PVC T
PVC Glue
2 - 1.5" PVC Cap
1 - 9v battery
STEP 2: Time to Start Gluing
Glue the fixed parts together using pvc glue
STEP 3: Add the Valve (no Glue Here)
These parts are not glued. They are just finger tight, so if something breaks later on you can fix it easily. It also allows some flexibility to aim the rockets.
I predrilled the hole for the fitting just smaller that the threaded fitting then used a wrench to tighten.
STEP 4: Launch Handle
I did not build my launch handle. I bought it premade at http://www.itsablast.com for around $15 but I will show you how to make one.
drill a hole in one cap the appropriate size for your momentary contact switch button. Insert switch and solder the negative (black) wire to the switch. Solder the negative lead of your 9v battery clip to the other terminal of your momentary switch. Connect the positive wire from the 9v battery clip to your positive wire using a small wire nut. Feed the wire through the 1.5" pvc pipe and slip the cap on without glue.
Drill a small 3/16" hole into the other cap. Tie a knot in the wire to keep it from pulling through the hole and feed it through so that the long wire tail is outside the launch handle when assembled. Install battery and slip the bottom cap onto your launch handle. Using wire nuts attache the launch wire to the sprinkler valve solenoid.
STEP 5: Have Fun
Give the glued parts about an hour to dry and then hook it up. I use 30-40 psi only but it may work at higher preasures.
I am not responsible if you jack this up to 200 psi and loose a hand or eye to flying pieces of PVC.
Be safe and Have a blast.
Complete launchers and parts can be purchased at http://www.itsablast.com
34 Comments
DanTDM 10 years ago
Use a QEV and steel pipe.
DanTDM 10 years ago
Never use PVC pipe. Use galvanized or copper pipe (black iron works too) and use a manual gas ball valve with a handle.
bracketracer 11 years ago
CudaEngineer 12 years ago
And Kipkay has instructions at http://www.youtube.com/watch?v=eNFfK5uo6D0
MonkeyBoy3217 13 years ago
JimKelleher 13 years ago
ghostWolf59 15 years ago
davemcp 13 years ago
We have had other people use this design with the bike pump and it has worked fine in it's current configuration. You could use larger diameter pipe for the accumulator legs or jus make them longer if you wish. If your valve seems to be opening slow or incomplettely you could add a second nine volt in series with the one on the plans giving you 18v to open the valve. This should give you a good solid voltage to open the valves. Most sprikler systems work on 24v so this could really help.
Dave
heathbar64 13 years ago
davemcp 14 years ago
BigMac96 14 years ago
davemcp 15 years ago
DJDeegee 14 years ago
TOCO 14 years ago
archimeech 14 years ago
Http://www.itsablast.com
and yes the rockets take 30-40 psi without too much problem. if you roll your rockets to 8.5" length instead of the 11" length we have had some take 60 psi or so. They really go at that pressure. But remember increased pressure means increased risk. I know someone will put the presure way up there and I am not responsible for damage or injury. I only recommend using 30-40 psi. Anything higher you do at your own risk.
Dave
thedolb 14 years ago
carl87gt 14 years ago
rock climber 15 years ago
