Introduction: Psp Chargeing Pill Bottle
this bottle has small easy to build circuit to power a PSP in need of a charge
((((((((not responsible for damage electronics)))))))
THINK YOU https://www.instructables.com/member/Jacob+S./ FOR THE IDEA BUT I TICKED IT A LITTLE BIT
HERE IS A PDF OF THE DIAGRAM I MADE BETTER TO READ THEN IN STEP4 AND 11
Step 1: Get Your Parts to Getter
i got all of these parts at radio shack but the pill bottle my old meds from when i got sick but that another story
CIRCUIT
switch http://www.radioshack.com/product/index.jsp?productId=2062503
1/8 mono jack www.radioshack.com/product/index.jsp
5volt regulator http://www.radioshack.com/product/index.jsp?productId=2062599
9 volt clip [http://www.radioshack.com/product/index.jsp?productId=2062218
PLUG
dc plug for psp http://www.radioshack.com/product/index.jsp?productId=2102598
(make shure it fits your psp )
1/8 mono plug http://www.radioshack.com/product/index.jsp?productId=2062452
(IT HAS TO BE MONO OR YOU WILL SHORT)
Step 2: Get Your Tools
multimeter http://www.radioshack.com/product/index.jsp?productId=2103174
wire
cutting tools
solder
iron(mine is butane)http://www.radioshack.com/product/index.jsp?productId=2062753
9 volt battery
helping hands
shrink wrap
Step 3:
now lets build
Step 4: Wire Diagram
fallow back to this if needed it will help the pdf is a true diagram i made
Step 5: STEP ONE
WIRE CLIP TO THE SWITCH
Step 6: STEP TWO
WIRE SWITCH TO 5 VOLT REGULATOR PIN INPUT
Step 7: STEP THREE
WIRE OUTPUT TO POSITIVE PIN
Step 8: STEP FORE
WIRE NEGATIVE CLIP -------------------------\
WIRE GROUND PIN ON REGULATOR ----->-------- TOGETHER AND SHRINK WRAP
WIRE NEGATIVE PIN ON JACK---------------/
Step 9: Test to See If It Works
put the plug in the jack and the battery in the clip and check the volts with the multimeter red probe to pos. and black to neg. like in the drawing the meter should say around 5 or less volts
Step 10: Put It Together
I PLUG IN A FRESH 9VOLT BATTERY OOPS TOO SOON
1- I DRILLED THE HOLES FOR THE JACK AND SWITCH
2 - THEN PLUG THE BATTERY IN
3 - AND MAKE THE PLUG NEXT STEP
Step 11: Make the Plug and Done
make the plug part see drawing
THINKS AND HAPPY MAKING
