Range and Accuracy Mod for Recon Barrel
Intro: Range and Accuracy Mod for Recon Barrel
Hey sweet nerf recon barrel mod. increases bullet range,and accuracy
STEP 1:
so what you do is take the recon barrel and unscrew it so it can open up. once opened it should look something like this. ( sorry that theres some parts missing i post everything i made after i moded it.)
STEP 2:
now take the tube in the center of the barrel out like so.
STEP 3:
now put the barrel back togather and screw everything back in but forget the sight and two orange half circles, those are unneeded.
STEP 4:
now just take the barrel and some tape and tape around any end of the barrel you like if you can see how i did mine try and do something like that.
STEP 5:
now stick the taped end into the front of the barrel which is the side where the sight use to be. make sure the barrel sticks in there nice and tight so that the barrel doesn't slip out easily. if your having trouble with that then keep on taping around the end where there is tape and repeat this until the barrel stays in the outer part of the barrel nice and tight.
STEP 6:
once youve done that your barrel should look like this. if it does it means youve done everything right.
11 Comments
JackDC2000 9 years ago
darknessfalls 13 years ago
Modguy241 13 years ago
wernarner84 12 years ago
Or even better, don't use a Recon. Longshot is beast.
KittehCatten 10 years ago
Agree to not using the barrel.
peyton14 11 years ago
hawke6789 10 years ago
GnomeMaster 12 years ago
16kuokhc1 11 years ago
SkyBladeWarrior 11 years ago
Capt. Kidd 12 years ago
