Realistic Paper Roses
105,251
562
52
Introduction: Realistic Paper Roses
There are many ways to make paper roses -- all documented online.  But..
The wheel!  I must reinvent it!
I don't know why I became fixated on making paper roses.   I thought it would be great to make some of them out of gift wrap for Christmas present decor.   I also had a strange urge to see what it would look like when burning.  (Check the last page of this instructable for the video)
(Please don't start singing that Marie Osmond song from the 70s.  I just got it to stop re-cycling in my head recently)
I came up with two ways to do it.  The better way (if you are lucky enough to have a programmable craft cutter) and the paper doll way, easier, but the results are mixed.  I will give examples of both ways of doing it in this instructable.
Step 1: The Idea
I deconstructed a rose by removing all it's petals and laying them out in order.  There seem to be around 24 petals (with 3 or 4 of them small and mutant).  The petals gradually descend in size as you get closer to the center.
Step 2: Materials List
Paper that will "accept a curl".  Bond paper works best!.  Thicker gift wrap with a bond paper like backing works very well.  The more wrinkle resistant the paper is, the less rose like, and more poppy like - the results will be.
Scissors
or (better)
White or wood glue
Something to be the stem.  I found bamboo skewers work very well, but for a realistic result, you may want to find something with a natural flex to it.  A bouquet of these roses on bamboo skewers feels awkward and besides bamboo skewers a very sharp and pointy and not safe for little kids.
optional
fine tip applicator for the glue
someone requested the MaketheCut files (.mtc) so I've attached those as well for those who are interested
Also attached now are SVG files which work with other types of cutters
Step 3: Craft Cutter Method
If you are lucky enough to have a programmable craft cutter, laser cutter or other CNC cutting device, this method provides the most realistic results.
Cut out some bond paper using the pattern provided below.
Skip to step 5
Step 4: Paper Doll Method
Fold two 2 inch and 3 inch widths of paper into successively increasing folds as illustrated in the first photo.
Cut as indicated in the photos:  (video soon)
Cut in a ways from the bottom, leaving about a half inch margin.
Cut away the lower portion of the petals.
Cut around the top portion of the petal.
Unfold the petals and then snip the middles of them about 1.5 inches in from the bottom along the fold
Step 5: Gluing the Petals to Be More Three Dimensional
Starting with the smallest petal, overlap the two halves of the split and glue together.  Hold the glued sections together for about 2 seconds with two fingers.  While holding that, take a moment to add a curl to the top part of the petal.
See this video for a demonstration:
Continue gluing the petals until you have a sort of helical shape of petals strung together as in the photo.
Step 6: Gluing the Petals to the Stem
Starting with the smallest petal, glue it to your stem and then apply glue along the bottom edge, wrapping the petal strand around the stem until you have glued all the petals on.
Finish up by curling any petals that need it.
There you go!   Yay, attractive flowers!
Step 7: A Rose Made of Ashes
As promised, a burning rose.
Be the First to Share
    • Holiday Decorations Speed Challenge
    • Plywood Challenge
      Plywood Challenge
    • Battery Powered Contest
    52 Discussions
    anniereets05
    anniereets05
    4 years ago
    SO difficult but SO pretty. I think you should find a way that origami paper is the only material with less steps to make it pre-teen friendly
    nea.savoca
    nea.savoca
    5 years ago on Step 7
    Since our business name is Ash & Rose, ashandrose.com I could not be more interested and delighted by the Ash Rose and the Burning Rose! Thank you!
    foobear
    foobear
    Reply 5 years ago on Step 7
    Fantastic! I'm glad you were amused by it!
    BobbiM1
    BobbiM1
    6 years ago on Step 7
    Do you have a way or technique that can bond the ash rose and stop it from crumbling or breaking afterwards that you use or prefer.
    foobear
    foobear
    Reply 6 years ago on Step 7
    I don't believe such a thing is possible, if you find a way, let me know that would be interesting.
    unicornstarr
    unicornstarr
    6 years ago on Introduction
    Lovely is there a version is SVG format so that I can use it on my cutting machine :) please.
    Thanks you
    foobear
    foobear
    Reply 6 years ago on Introduction
    I added an svg version for you on step 2
    violeta571
    violeta571
    6 years ago
    the burning rise looks better, I love it
    Popopopper
    Popopopper
    8 years ago on Step 7
    whooooa the burning rose is so pretty
    foobear
    foobear
    Reply 8 years ago on Step 7
    yah, I love it. thank you!
    overflow636
    overflow636
    8 years ago on Introduction
    Could you post the template file for the cricut, i have a different machine available , but any vector format should work.
    Thanks!
    foobear
    foobear
    eh, sorry, finally got a round tuit. I attached the .mtc files to the materials page.
    curious youth
    you could use a thick gauge copper wire for the stem. it wouldnt be too expensive and you could choos alot of different coulours due to the insulation.
    yes im a guy looking at this. some girls need impressing ;)
    This is very creative but takes time!!! i love it though wish i had somebody to do it for me!!
    foobear
    foobear
    Yes, it takes time. there are lots of tutorials on line for making paper roses, not quite like this one, but maybe satisfactory to many...
    CookieMonstah123
    CookieMonstah123
    Yeah!! Um... Well i like thease roses maybe u could try making them for your hair by attaching a clip!!! LOL
    blackslax
    blackslax
    9 years ago on Step 6
    Wow.
    This is great...really great.
