Scalable Polygonal and Polyhedral Geometric Construction System
Intro: Scalable Polygonal and Polyhedral Geometric Construction System
Scalable 2D (polygonal) and 3D (polyhedral) construction system for use in the construction of various geometries i.e geodesic domes, space frames, trusses etc
The system is comprised of
- cylinders (hubs)
- struts (rectangular section steel, aluminium, acrylic or other )
- jaws ( 4 x same shape - two with slot for compression spring and two with hole for small pin to compress spring)
- high tensile bolts
- nylock nuts ( have explored quick release fasteners i.e bicycle wheel skewers etc )
- fail safe jaw washers
- hub centre eye bolt (for rigging/hanging)
I designed this configuration to employ minimal manufacturing processes, it is laser or plasma cut (found laser provided a smoother surface finish) . The first prototype was originally create by the camp fire in the bush with basic hand tools .
The concept was the extrapolated , to a much more sophisticated and expensive design, prototype was 'grown' via optical fabrication in liquid ultraviolet curable photopolymer "resin" was to then be manufactured from injection moulded Nylon6 .
modelled around 'handcuffs' and 'hose fittings' ...
financial and other personal issues halted the project there ...
that was about 8 or so years ago ...
- cylinders (hubs)
9 Comments
C60 11 years ago
3schrw 3 years ago
BoilingLeadBath 11 years ago
What's the purpose of the "washers" (those pieces installed coaxial with the ring)?
Are there features to the "fingers" that hook over the edge of the ring that we can't see in the picture?
Xmissile 10 years ago
sleeping 11 years ago
rimar2000 11 years ago
Dream Dragon 11 years ago
Thank you for sharing them.
C60 11 years ago
C60 11 years ago
