Introduction: Secret Compartment in Wall
very easy
Step 1: Materials
you need a frame for a light switch or something like that and a magnetic tape
Step 2: Find Location
Step 3: Get Materials
note that magnetic tape is something you most likely have to buy
Step 4: Put Tape in the Back of the Frame
Step 5: Press the Tape in the Back
Step 6: Just Put It in There (and If Its Magnetic It Should Work)
Step 7: If It Falls Then Take Off Some Magnets Cause It Might Be Too Heavy
Step 8: MAKE SURE THE BOX YOU USE TO HIDE THE STUFF IS NOT IN USE OR IT IS ABANDONED LIKE THIS BECAUSE IF THERE ARE STILL WIRES THERE THEN IT MIGHT ELECTROCUTE YOU
Step 9: ALSO Make Sure the Frame Is EXACTLY THE COLOR OF THE STORAGE OR IT WILL BE DEFECTIVE AND EASY TO SPOT
Step 10: Very Easy to Use Just Open It Put/get Something In/out and Put Frame Back in That Easy
Secret Doors and Compartments Contest
8 years ago on Introduction
i will give you a million dollars just for making this invention YOU ARE A GENIUS
