Sew Up Hole in Jeans
32,310
34
8
Introduction: Sew Up Hole in Jeans
sew up that nasty hole in your favorite jeans without an iron on patch.
Step 1: Step One
The hole in these jeans are at the knee, to fit them onto the sewing machine you need to flip them inside out and take out the outside seam. but just enough to fit it on your machine with a little wiggle room to sew.
Step 2: Step Two
Now to start sewing, basically you go forward and backwards to make a zigzag effect rotating the jeans just a little after each line, so you move across the hole, rather then staying in the same spot.
I used white thread and did little lines, you can make them longer or use a different color for a stylish effect.
Step 3: Step Three
Now that you have your hole all sewn up its time to sew up the hole you had to make to fix them. just line the edges of the fabric up together "they should go together pretty good because they have a crease from where the thread used to be" and just sew them up where the seam was before.
and there you have it, no more hole.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Sculpt & Carve Challenge
    • Meatless Challenge
      Meatless Challenge
    8 Comments
    =SMART=
    =SMART=
    14 years ago on Introduction
    Nice, i should have seen this earlier because i had a small hole and then i went on trampoline and now its massive :(
    JaniePatricia
    JaniePatricia
    Reply 14 years ago on Introduction
    aw man thats bad, sorry that your pants riped. you can try and do this to a bigger hole like yours, unless its a crazy shape and would be too much work.
    =SMART=
    =SMART=
    Thanks :P i went to the Levi's store and got a new pair in the sale !, the hole on the old jeans was S shaped so i just used a needle and thread and sewed it up, looks messy though :D
    killerjackalope
    Haha, nice 'ible, though I published This and hour or so before you, I probably should have done it your way... However look at the pics, the jeans are even similar weight and whatnot...
    Also for the macro pics: Good job getting bright close-ups, people usually fall down on this point, as a pointer try using a baby tripod or resting both your arms on solid object to help with blurring, it's annoying when the thing's sitting in your lap but it can be done...
    JaniePatricia
    JaniePatricia
    i saw your 'ible too its really cool, and thanks for the input i do have a mini tripod that came with my camera i forgot i had it tho, so next time i will use it. Thanks man.
    killerjackalope
    killerjackalope
    Thanks, it's always annoying to get good macros on stuff like this, they don't reflect enough light...
    mdmoose29
    mdmoose29
    ive heard about using baby tripods before... but mine will never stay still long enough. the little buggers always throw up or fall down or something. any suggestions?
    killerjackalope
    killerjackalope
    Well I have a fairly hefty creative compact, an olympus Sp-560UZ and I have great results with the gorilla pod, just the baby one, granted most of the time I just put a solid object under my hand holding the camera and that works nicely...
