Simple Arduino Virtual Keypad
Intro: Simple Arduino Virtual Keypad
Hello i just created this simple keypad to unlock doors or do some other stuff
requirements:
computer(any os)
arduino
optional for building relay switch
relay 5v
diode 1n4007
resistor 270 ohm
optocoupler
external supply
requirements:
computer(any os)
arduino
relay 5v
diode 1n4007
resistor 270 ohm
optocoupler
external supply
STEP 1: Bulding Relay Switch
STEP 2: Upload Code to Arduino
char inData[20];
char inChar=-1;
byte index = 0;
void setup(){
Serial.begin(9600);
pinMode(12, OUTPUT);
char Comp(char* This){
while(Serial.available() > 0)
if(index < 19)
inChar = Serial.read();
inData[index] = inChar;
index++;
inData[index] = '\0';
if(strcmp(inData,This) == 0){
for(int i=0;i<19;i++){
inData[i]=0;
index=0;
return(0);
else{
return(1);
void loop()
if(Comp("6729")==0){
Serial.write("GRANTED");
digitalWrite(12,HIGH);
delay(50000);
digitalWrite(12, LOW);
char inChar=-1;
byte index = 0;
void setup(){
Serial.begin(9600);
if(index < 19)
index++;
inData[i]=0;
index=0;
return(0);
else{
return(1);
void loop()
delay(50000);
STEP 3: Changing Password
if you want more than 19 digits just change "char inData[20];"to number you need and all 19 to your number-1
STEP 4: Run Arduino Virtual Keypad
now all you need to do is unpack ziped files and open (for windows)application.windows32 and run sketch_130540a.exe
2 Comments
Amarotica 8 years ago
Thanks for the tutorial! I will definitely build this soon. One question, could I use a arduino 4*4 keypad instead of the pc and do you have any idea how I could make the ABCD buttons each turn on a different relay?
Thanks again
lmowry 10 years ago
