High Voltage Steampunk Plasma Night Light
Introduction: High Voltage Steampunk Plasma Night Light
About: I love all things nature. I have hiked from Mexico to Canada via the Pacific Crest Trail and Durango to Denver via the Colorado Trail. This life is where the name Lone Ginger comes from. I also summit 14ers an…
Based on the very detailed instructables by Junophor and Admiral Aaron Ravensdale I have built a steampunk inspired night light. Using a simple jewelry box, some scrap brass and copper bits and pieces, a High Voltage circuit built up from a single use camera and a little bit of imagination . Because others like Junophor and Admiral Aaron Ravensdale have already put in the work on there instructable I have chosen to just give an example of what can be done based on the ideas and knowledge of these two steampunkers, along with others I just happen to see their work first. I am new to the steampunk world and will be doing other pieces in the future, if you like my work and find inspiration in it please leave comments, I do appreciate constructive criticism!
Step 1: Supplies
-Jewelry box or other small box, preferably with built in compartment (or space to build if you wish) for electronics
-Copper bits, fittings, soft copper tube, etc.
-Brass bits, clock movents, etc.
-Single use camera
-Low voltage switch
-Battery holder
-Flicker flame bulb or other figural neon discharge bulb. In my testing with light bulbs that work to produce the desired plasma affect, I have found that vintage figural bulbs that are in the neon discharge group always work well. In testing I have used a Santa Claus bulb, a Zodiac charm bulb and of course flicker flame bulbs. All three bulbs are from different manufacturers and all work and all three can both produce a plasma affect or be driven to function in the traditional way by just attaching your ground to the ground off the bulb.
-Brass allthread and brass nuts
-copper(stained glass) or other conductive foil
-tube/pipe cutter
-drill
-dremmel, various bits
-torch
-solder, electrical and plumbing grades
-soldering iron
-helping hands
-clamps
-vise
-general hand tools, files, screw drivers, etc
Step 2: Design and Build
Come up with a concept and do your best to execute said concept. This box uses the lid being closed to complete the circuit and some random clock gears to give it a more dramatic look in alternating between brass and copper. Copper foil is used to create a permanent plasma glow. The electronics are hidden in a built in compartment for the safety of you and the piece, while the amps are low the 200+ volts at the bulb is enough to let you know it is there. I may eventually put a solar charger off the back but as for now it is just fine the way it is
If you are looking for used cameras and cant find any, try a independent NON-coporate camera shop that still developes film, dont bother with walgreens, etc unless you know some one working there. If you still have no luck there is a seller on ebay selling the fuji circuit boards along with kodak(there is info on haking kodak and othe boards if you look) for a few dollars. If you are not comfortable with building the circuit, private message me, I can build you one with enough cable to do as you please with it with just a few easy off the board solder points. There would be a minimal charge + shipping, I aquire the boards free and it doesnt take all that long to build one.
Step 3: Circuit Board
Junophor has already provided a detailed fuji circuit board hack here https://www.instructables.com/id/High-voltage-power-supply-for-Nixies-CFL-Neon-Gl/ and here is a hack for another manufactureres board by The_Don125 https://www.instructables.com/id/Disposibal-Camera-Nixie-Tube-Driver/. A few other places on the web you can find hacks and there are a few videos on you tube as well that are very detailed.
Step 4: Updated
I wired in a 2.5v 500 ma output ac adapter that was purchased from a local thrift store for .99. I have run a light now for around a week straight with out the board burning up, it is not in an enclosure so that will be the next test to find out reliability.
Be the First to Share
    • 3D Printed Student Design Challenge
    • Paint Challenge
      Paint Challenge
    • Edible Art Challenge
    7 Comments
    LoneGinger
    LoneGinger
    Thanks. The design is my own but not completely original. You should take a look at some of the other plasma bulb builds that I got my inspiration and know how from.
    Moem
    Moem
    Looks cool! Any hints for the circuit? Maybe even some schematics?
    LoneGinger
    LoneGinger
    you can find a very detailed instructable on fuji built circuits done by junophor here https://www.instructables.com/id/High-voltage-power-supply-for-Nixies-CFL-Neon-Gl/, and an instructable for another manufacturer here https://www.instructables.com/id/Disposibal-Camera-Nixie-Tube-Driver/
    seamster
    seamster
    This is really cool looking! And pretty simple to make, it appears.
    Thanks for sharing your first instructable!
    LoneGinger
    LoneGinger
    thanks, it was fairly simple as my design shows but I am very limited in space and equipment currently.
