Surgical Tubing Paint Mine
Intro: Surgical Tubing Paint Mine
this is a paint mine that uses surgical tubing as a propelant to shoot paint up to about 16 feet. it is very cheap and easy to build. there are some mines like these on the market but go for about $50 each. you can make 6 for less than that. heres how!
STEP 1: Materials
2feet of 2inch abs pipe (you can make about 6 of them 4inches tall)
12- 2inch abs end caps ( if you want to make 6 mines)
A few feet of 1/4inch surgical tubing (hardware store, need about a foot per mine)
Some thin sheet metal or plastic
1/2inch pvc pipe (only need an inch per mine)
2inch cotter pins and key rings(enough for how many you make)
Epoxy
Wood to make a 1inch tall x1inch wide x1inch long 45degree angle wedge (1 per mine)
Some tent stakes (1 per mine)
Large hose clamps (to go around the 2inch pipe and the tent stake)
Small zip ties
Gasket seal
Epoxy
Small zip ties
Gasket seal
STEP 2: Body
Cut the 2inch pipe to about 4inches.
STEP 3: Pressure Tube
Cut a piece of 1/4inch tubing to 12inches. On one end put some gasket seal and tie a knot in the tubing as close to the end as possible. You want the gasket seal to be in the knot. You dont have to do this but i have a hard time with this leaking.
STEP 4: Top Cap
Take one of the 2inch end caps and drill a hole whos center 3/4inch from the edge of the cap and a little bigger than the 1/4inch tubing.
STEP 5: Trigger
Cut some 1/2inch pvc to 1inch. This is the trigger.
STEP 6: Trigger Holder
Take some wood and cut a wedge that is 1inch wide X 1inch tall X 1inch long with the slope at about 45degrees.
STEP 7: Trigger Holder Sides
Cut out some holders that mount on the sides of the wedge and that will hold the pvc trigger in place and that also allows for a safety pin to go through the trigger.
Epoxy the wedge and the holders together and let dry!
After the epoxy had set you will want to drill a small hole for a zip tie and the cotter pin in the holders. You will want the zip tie holes to be just above the tubing height. On the holes for the cotter pin, place the trigger between the holders and drill a hole just big enough for the cotter pin through the holders and trigger at the WIDEST PART OF THE TRIGGER. You may also want to drill a hole for the trip wire in the trigger at this point.
STEP 8: Glue the Tube Holder to the Top Cap
Take this assembly and the 2inch cap with the hole in it and epoxy the wedge to the cap. You want the wedge about 1/4inch away from the hole. Let the epoxy set.
STEP 9: Finnishing
After the epoxy has set put the tubing through the hole with the knot on the inside of the cap and put on the zip ties to hold it in place. You dont want these to pinch the tubing.
Put the hose clamp and the caps on the pipe. Slide the stake in and tighten the hose clamp.
Make sure the knot in the tube is at the bottom of the mine and mark where the tubing is at the cap and cut the end of the tubing so about 5inches are coming out of the mine and your done!
STEP 10: How to Use
Fill up the tubing, mine holds about 6oz. You can use a squirt bottle or a pump out of a squirt gun(search for paint grenades on instructables, this was the inspiration).
Fold the tubing up and back and put in the trigger and safety pin.
Find a place to deploy the mine. Stab into the ground with squirting side facing enemy.
Attach tripwire and tie off across from mine. Remove safety pin. The mine is now live and ready to paint!
28 Comments
SMOKINACE99 10 years ago
peter201943 10 years ago
dp mac 12 years ago
tobster9103 12 years ago
1: it holds the tubing at an angle so the fluid as a 45 degree path instead of a vertical or horizantal path.
2: it is part of the safety and trigger system. The aluminum parts that ar on the side of the wood block hold the tubing and trigger straight when the trip wire is pulled and they also have a hole drilled for a cotter pin to keep the trigger from being accidentally pulled off. You can make this however you see fit. This is just how I did it.
vwsinner 12 years ago
blackboarder77 13 years ago
tobster9103 13 years ago
linden wulfe 12 years ago
camoguy1 13 years ago
john209 13 years ago
thatoneguy112233 13 years ago
mr_goodbytes 14 years ago
sabre 14 years ago
tobster9103 14 years ago
couldn't have explained it better my self! It works pretty well. It only shoots in a narrow stream so it's accuracy could be better but if it hits they will definitely be marked. I wish I could find a nozzle that will spray in a fan pattern like my other mine.
kusichkid 14 years ago
duckythescientist 14 years ago
